| Placio74 |
| Posted: Oct 10 2012, 11:34 PM |
VideoAudio
Also, I put these plugins (and ACM codecs) on SkyDrive
| Gral |
| Posted: Oct 12 2012, 03:54 AM |
Mirror of fccHandler's page:
gral.y0.pl/~fcchandler |
| v0lt |
| Posted: Nov 17 2012, 09:30 PM |
| QUOTE (Gral @ Oct 12 2012, 03:54 AM) | Mirror of fccHandler's page:
gral.y0.pl/~fcchandler | does not work
another mirror -> http://www.mediafire.com/?hi5xv5gfzi55r
somebody save the source code? |
| ale5000 |
| Posted: Nov 17 2012, 10:13 PM |
Look here => http://gral.y0.pl/~fcchandler/
| v0lt |
| Posted: Nov 18 2012, 04:15 AM |
I can not open. |
| Posted: Nov 18 2012, 12:03 PM |
@v0lt Here's a copy of the site (web pages, source code etc) https://dl.dropbox.com/u/17024916/MyUploade...lers%20Site.zip
If you 'lose' web pages like fccHandlers missing page then "the wayback machine" is a good place to find the previous version http://archive.org/web/web.php
| drshi |
| Posted: Dec 3 2012, 08:13 PM |
Hi "ale" --
When I couldn't open MPEG 2's you referred me to the appropriate plugin; but now I'm having the same problem with MPEG 1 (VCD)s -- "No video frames found"; but I don't see a relevant plugin here. Help, please.
Thanks, Rob |
| jbar61 |
| Posted: Dec 4 2012, 02:05 AM |
First of all, thanks for all the previous help.
Is there a way to load ".ts" files and edit them? How? |
| loin2kolpotoru |
| Posted: Mar 24 2013, 08:23 AM |
Given that fccHandlers plugins are the best plugins for virtualdub and the original page is offilne from long time, Someone should upload fccHandlers plugins & sources to sourceforge.net for the archiving and easy access. |
| Trepack |
| Posted: Mar 24 2013, 08:48 AM |
| QUOTE (loin2kolpotoru @ Mar 24 2013, 08:23 AM) | | Given that fccHandlers plugins are the best plugins for virtualdub and the original page is offilne from long time, Someone should upload fccHandlers plugins & sources to sourceforge.net for the archiving and easy access. |
Here are the Plugins
URL: fccHandler's |
| loin2kolpotoru |
| Posted: Mar 29 2013, 05:00 AM |
| QUOTE (v0lt @ Nov 18 2012, 04:15 AM) | I can not open. | I am also not able to open that page and i was asking for uploding those files to sourceforge for the longterm preservation. Even if the other mirrors disappirs the sourceforge is one place where they will always be found. |
| -vdub- |
| Posted: Mar 29 2013, 06:11 AM |
I agree Sourceforge would be best place for all of them. Not likely to disappear with many servers worldwide that that mirrors all the sourceforge data |
| loin2kolpotoru |
| Posted: May 31 2013, 08:44 AM |
Thank you for uploading fcchandler's plugins to http://sourceforge.net/projects/fcchandler/files Please also provide a alternate download at soruceforge of complete plugins in one package this will ease task for those who need all the plugins. |
| -vdub- |
| Posted: Jul 10 2014, 07:09 PM |
SubLog Extractor is a VirtualDub filter designed to extract hardcoded subtitles from a video stream
Extracting hardcoded subtitles is really a two parts job :
1) Identifying the changes in the subtitles frames, dump them into bitmaps files, and create a time index for them.
2) (optionally) Applying OCR to the resulting bitmaps to extract text data
SubLog Extractor Filter is taking care of part #1, while an external application such as SubRip can proceed the OCR from the files dumped by SubLog Extractor.
More precisely, SubLog Extractor works the following way:
A. Pre-processing Filtering the input (optionnal).
B. Temporal Processing Differential scanning & frame selection.
C. Post-processing (VobSub mode only) Formating the output.
Web Site Download Filter Download SRC |
| ale5000 |
| Posted: Feb 27 2015, 02:11 AM |
There were links in the first post that were pointing to iLivid (sites changed over the time), I have removed them but if you have downloaded it I suggest to do a virus scan.
