| L.H.V.F. |
| Posted: Jul 14 2011, 04:19 AM |
| QUOTE (ale5000 @ Jul 13 2011, 03:33 PM) | | QUOTE (L.H.V.F. @ Feb 26 2011, 02:03 AM) | for reasons of compatibility with .OGM file, for example?
I know that this version is old, but until now, I not seen a version to open .OGM video files. |
The latest version of the Matroska input plugin support Theora video, it was already supporting Vorbis audio. This should cover almost all .ogg/.ogm files (after remuxing them to mkv). |
Hi, ale5000
After I have tryed to open a Theora video ".ogg" in VirtualDubMod, and the program crashed. Then I have decided to demux, using direct stream for both audio and video, and try to open with Matroska Input Plugin using ffmpeg-18639 win32 CLI, according of one tutorial:
http://forum.doom9.org/archive/index.php/t-134350.html
More in:
http://forums.virtualdub.org/index.php?act...l=ffmpeg&st=285
Message in VirtualDub:
http://s13.postimage.org/5842bl26v/problem_decompressor.png
Syntax utilized:
ffmpeg -i How_fast.ogg -vcodec copy -acodec copy Output.mkv
I want to know if the audio is really "0x566F"?
I thank return, L.H.V.F. |
| ale5000 |
| Posted: Jul 14 2011, 01:39 PM |
@L.H.V.F.: For remuxing it is a lot simpler with MKVtoolnix.
With Vorbis audio you are limited in Direct Stream Copy (since there isn't an ACM codec); so you can't convert audio but you can still cut. For Theora video instead you can do everything.
| L.H.V.F. |
| Posted: Aug 11 2011, 01:43 AM |
post removed |
| L.H.V.F. |
| Posted: Aug 11 2011, 03:31 AM |
Hi, ale5000
I point 2 updates for this list:
New QuickTime plugin, by fccHandler developer:
http://fcchandler.home.comcast.net/~fcchandler/Plugins/QuickTime/index.html
And, a new version of the DirectShowInputDriver, by Avery Lee developer:
http://www.virtualdub.org/beta/DShowInputDriver-0.9.zip
New version is: DShowInputDriver-0.91
Newest versions at: http://forums.virtualdub.org/index.php?act=ST&f=7&t=15093&hl=dshow
| QUOTE (ale5000 @ Jul 13 2011 @ 03:33 PM) | | QUOTE (L.H.V.F. @ Feb 26 2011 @ 02:03 AM) | for reasons of compatibility with .OGM file, for example? I know that this version is old, but until now, I not seen a version to open .OGM video files. |
The new version of the Ffmpeg Input Driver, 0.6, now supports .ogm files.
I thank reply, L.H.V.F. |
| L.H.V.F. |
| Posted: Oct 12 2011, 10:32 PM |
| QUOTE (ale5000 @ Jul 14 2011, 01:39 PM) | @L.H.V.F.: For remuxing it is a lot simpler with MKVtoolnix.
With Vorbis audio you are limited in Direct Stream Copy (since there isn't an ACM codec); so you can't convert audio but you can still cut. For Theora video instead you can do everything. |
Hi, ale5000
Is possible to convert Vorbis audio in windows. The procedure utilized would be to use FFmpeg to demux, (I use these win32 build - FFmpeg, but there are front-ends/GUIs for the same - http://www.videohelp.com/tools/ffmpeg), via CLI, and demuxed for the Matroska, without loosing quality, I can convert it to 'wave audio', using Foobar2000. Then in VirtualDub is possible to use 'audio from other file...' dialog, and process the video.
Page of reference:
Foobar2000
Thanks, L.H.V.F. . |
| ale5000 |
| Posted: Nov 29 2011, 07:41 PM |
I have updated the list on the first post.
| L.H.V.F. |
| Posted: Dec 1 2011, 02:57 AM |
| QUOTE (ale5000 @ Nov 29 2011, 07:41 PM) | | I have updated the list on the first post. |
Hi, ale5000
You have forgotten the link (same source) of the x86 version (32 bits) of the "Experimental QuickTime Plugin" by fccHandler in the list.
| ale5000 |
| Posted: Dec 1 2011, 03:01 AM |
| QUOTE (L.H.V.F. @ Dec 1 2011, 03:57 AM) | You have forgotten the link (same source) of the x86 version (32 bits) of the "Experimental QuickTime Plugin" by fccHandler in the list.
Thanks, L.H.V.F. . | No, it is present in the list "QuickTime / MPEG-4 / 3GPP (MOV MP4 M4V QT 3GP 3G2) (by fccHandler)"
| L.H.V.F. |
| Posted: Dec 4 2011, 02:14 AM |
| QUOTE (ale5000 @ Dec 1 2011, 03:01 AM) | | QUOTE (L.H.V.F. @ Dec 1 2011, 03:57 AM) | You have forgotten the link (same source) of the x86 version (32 bits) of the "Experimental QuickTime Plugin" by fccHandler in the list.
No, it is present in the list "QuickTime / MPEG-4 / 3GPP (MOV MP4 M4V QT 3GP 3G2) (by fccHandler)" |
Hi, ale5000
I had confused the "fccHandler plugin" with the "tateu's QuickTime modded version" (this last mentioned, removed from the list). Why don't you let also the updated version of "tateu's QuickTime plugin modded version" in this list? I consider your mod, but in this Forum, there are others mods (and the original) previously done.
| ale5000 |
| Posted: Dec 4 2011, 02:34 AM |
Nothing is missing, if you follow the link of the mod you can see that there is the mod and the original one.
| gzii |
| Posted: Jan 16 2012, 09:45 AM |
Could be possibe to add pause option to mpeg2 plugin. Example: Whwn loading long mpeg2 files - 15gB & HDD is overloaded.
Thank you anyway for these plugins. |
| v0lt |
| Posted: Feb 18 2012, 06:16 AM |
Add the ACM codecs to the list. Speex Voice ACM Codec 1.0.1.1 VoxWare MetaSound Audio CoDec 1.6.0.17 |
| Barnister |
| Posted: Jun 26 2012, 07:37 PM |
What's the VDub Dazzle Hack do, please? |
| TravisR |
| Posted: Oct 10 2012, 04:42 AM |
Hello all,
All the fcchandler links are returning a page that is "Temporarily Disabled". These files wouldn't happen to be mirrored somewhere would they?
Thanks in advance,
Travis |
| Abrazo |
| Posted: Oct 10 2012, 05:21 PM |
Not a mirror site, but you can find copies of fccHandler's plugins on it: - http://www.videoaudio.pl/infusions/pro_dow...el/download.php
You can search (Szukaj) on keywords to find what you need (like for example wmv // or aac ; quicktime ; plugin ; virtualdub ; ...). |
