Experience With Deinterlace Filter
the_wildcard
Posted: Jul 28 2004, 11:27 PM
Okay, I have tried several deinterlace filters with virtualdub. If you have experience with these filters and or prefer them, please comment.
I am deinterlacing a 6 minute, captured footage of a TV reality show, by connecting my DV camcorder to my cable television. 720x480 - NTSC. Using divx 5.11 pro to encode with 3 passes.
Built-in deinterlacer plugin with Virtualdub
(Blend)No visible horizontal lines during fast movement, but blurrs video a bit. Any reccommendation on solving this? Maybe running using Virtualdub's built-in sharpen filter?
Deinterlace MAP plugin with Virtualdub
(Default settings) Recommended by Doom9's analog capture guide, I find it doesn't deinterlace as well as the regular interlace, but doesn't blur as much too. I am going to try to increase the threshold settings. Any reccomendations on the settings?
Smart Deinterlace plugin with Virtualdub
(Default settings) Increased encoding time, and I noticed that there as more noise in the video, but could just be my eyes tricking me. Does anybody have any expereience with this filter?
Field Bob with Virtualdub
(Even-qtr down, Odd-qtr up) When I used this filter, on the reccomendation of www.100fps.com, there was movement up and down in the video. Did I flip the settings? I thought the field bob filter prevents the movie from bobbing?
Now one filter I haven't used is Smooth Deinterlace by Thalin. I found from reading the forums that you have to split your video into odd or even fields? Since I am not using avisynth, I don't think I can do this.
rfmmars
Posted: Jul 29 2004, 01:28 AM
AS I said try Alparysoft deinterlace for Virtualdubxxx.
richard
www.photorecall.net
i4004
Posted: Jul 29 2004, 06:08 AM
best deinterlacing filters are smart deinterlace(graft...don't "compare color channels") and deinterlace area based (thalin)
these are best deinterlacing filters....
deinterlace smooth(also thalin) was ported to avs(smooth deinterlace) and this is framerate doubler (60hz video will become 60fps video)
my signature:
the_wildcard
Posted: Jul 29 2004, 05:48 PM
Okay, I'll download the older deinterlace area plugin by thalin and also try smart deinterlace plugin again but without the compare color channels setting.
Btw, I also tried using the built in deinterlace plugin (blend) and then tried using a sharpen value of 11 with no visible difference.
snoclowNIX
  Posted: Jan 26 2005, 11:27 AM
Alparysoft - I wonder how good it is compared to freeware?
How to register Deinterlace filter?
    To register the given filter you need to pay 40$. .... After that the filter will be registered and the logo will disappear from the right corner of output frame. ...
    When registered one may use all implementations of the given filter (listed in section How to use Deinterlace filter).
neuron2
Posted: Jan 26 2005, 01:31 PM
5 replies since Jul 28 2004, 11:27 PM Track this topic | Email this topic | Print this topic
