| ayanami0 |
Posted: May 19 2004, 10:00 AM |
Does anybody know if there is any vDub plugin in development or is already out that does a 3:2 pulldown? I have been looking around and don't seem to find anything that can let me do that. Thanks! |
| stephanV |
| Posted: May 19 2004, 10:34 AM |
you can do 3:2 pulldown in video--->framerate
for obvious reasons you cannot use 'direct stream copy' in this mode but must select 'full processing mode'
| Cyberman |
| Posted: May 19 2004, 06:13 PM |
| QUOTE (stephanV @ May 19 2004, 11:34 AM) | | you can do 3:2 pulldown in video--->framerate | How? All I see is the IVTC, the Pulldown removal.
-------------------- Matroska/MKV ? |
| stephanV |
| Posted: May 19 2004, 07:18 PM |
whoops... youre right... i thought he meant removal though...
but ive never seen anything that can do 3:2 pulldown (never seen anyone who wanted to do that either), maybe avisynth?
| ayanami0 |
| Posted: May 20 2004, 01:52 AM |
Yeah, I've tried, but didn't do anything close to a pulldown. What I wanted was something similar to the 3:2 Pulldown feature of TMPGENC, which nicely converts a 29.97 interlaced video into a perfect 24frame progressive video.
AVISynth? Isn't it a separate program? I'd like to stick to using Virtual dub as much as possible, unless AVISynth is a plugin . |
| Posted: May 20 2004, 03:59 AM |
Other way around -- 3:2 pulldown takes 24 fps source and makes 30 fps output. It's so named because pairs of fields are pulled from the source and pushed into the output in a 3:2:3:2 alternating pattern. |
| Cyberman |
| Posted: May 20 2004, 07:07 AM |
| QUOTE (ayanami0 @ May 20 2004, 02:52 AM) | | What I wanted was something similar to the 3:2 Pulldown feature of TMPGENC, which nicely converts a 29.97 interlaced video into a perfect 24frame progressive video. | That is the 3:2 Pulldown removal. Where every 3 frames 2 are interlaced - one is removed that way. Also known as IVTC - InVerse TeleCine. That you can do with VIDEO->FRAME RATE - the last segment "Inverse Telecine(3:2 Pulldown removal") is what you need. Set it to "Reconstruct from fields - adaptive". That will eliminate every fifth frame, giving you 24fps. You still have to deinterlace, though - as every fourth frame still is interlaced. Use Smart Deinterlacer for that, IŽd recommend.
