Color Balance?, Is a filter for color balance available?
iupl
Posted: May 27 2003, 07:14 PM
Hello,
I downloaded and installed the software, all runs fine. However I could not find a filter to modify colors. In my case I made a video unterwater and would like to enhance red. Is such a filter available?
Thanks for any answers,
Peter
mikitow
Posted: May 28 2003, 06:00 PM
There´r a lot of this king of filter.
Try this one: Red/Green/Blue Adjustment Filter for VirtualDub
Bovski
Posted: May 28 2003, 10:16 PM
you may also want to try the white balence Filter by Jim Leonard
http://shelob.mordor.net/dgraft/whitebalance.html
The Jackel
Posted: Jun 2 2003, 04:18 AM
Hello,
I've been tring to capture with Vdub and this msg always appears..... Cannot find this driver to draw this RGB image Format. Preview and histogram functions will be unavaliable..... I went to the RGB site that u have and i downloaded and installed into the plugins and still doesnt work so can anyone help thanks blink.gif
iupl
Posted: Jun 7 2003, 07:38 PM
Hello,
thank you for your answers, this helped already a lot, the whitebalance filter is really helpful, a combination of the two filters gives a satisfactory result. However, I do not get the same result as using Images/Adjust/Levels is Photoshop where I can select the histograms for RGB separately. That would be the filter I really need for the best result.
Maybe such a filter is also available?
Anyway, thanks for your help!
Regards, Peter
4 replies since May 27 2003, 07:14 PM Track this topic | Email this topic | Print this topic
