| dancios |
| Posted: Feb 24 2003, 09:38 AM |
hi,
sorry for my english
but i hava a problem
when i will compress the sound in the avi and chose the codec, i cant chose anyone, i have on the left site all codecs, 3 mp3 codecs. but no from then works, some when i klick on SHOW ALL..........but when i select one, than VD say CANT INIZLIES AUDIO..........but the avi have 1000%%%% sound...............what should i do...........or where can i setup the audio codecs for VD.....please help...... |
| gauchobravo |
| Posted: Feb 24 2003, 02:36 PM |
Do you have this problem with this movie only? It doesn´t look as a Vdub problem. Looks like a codec problem. If yours is a small movie you could "save wav" uncompressed, and then compress from the wav file
| ChristianHJW |
| Posted: Feb 24 2003, 02:47 PM |
moved to codec discussion section
Can you tell us exactly WHAT MP3 codecs are listed in your codec list ? Do you have to tick 'show all codecs' first to see them in the list, or do they show up on first opening ? What sampling rate is your audio track ?
| valja |
| Posted: Feb 24 2003, 04:16 PM |
Looks like the problem is in audio codec used in the avi file - VDub can't decode sound from the avi file. Therefore VDub can't offer suitable formats for encoding. I suspect there's something like AC3 - in this case you will see just the same picture - right box will be empty, because there's nothing to encode - source audio can't be decoded. You can tick box "Show all formats" and will see all possible formats for all codecs, but it's useless - you can't recode sound.
Open your avi file in VDub, then look to "File" -> "File Information..." and tell, what you see in the section "Audio stream". |
| dancios |
| Posted: Feb 25 2003, 09:38 AM |
thanks @ valja.......
| ChristianHJW |
| Posted: Feb 25 2003, 11:04 AM |
Hmm ... seems your audio is uncompressed PCM, sou you should be fine here, but why is the sample rate not precisely 44100 Hz but something like 44094 Hz ? Maybe this is the reason, as most audio codecs require a specific input sampling rate.
IIRC there is a way to force the sampling rate to be 44100 Hz, but i cant remember how to do it right now ... guess i am getting old .. lol
| valja |
| Posted: Feb 25 2003, 08:01 PM |
Just go to "Audio" -> "Conversion" and select there 44100KHz. |
| dancios |
| Posted: Feb 28 2003, 12:58 AM |
i dont know
......and when i capture video and audio.....I HAVE NO DROP FRAMES......but the sound is nos SYNCRON with the video!!!!!!!!!!!!
i capture with asus digital vcr
because i can capture in 750 * 5??
ant with VD i can some in 320*250 if i take 640*480 i haved some 12 FPS per seconds! |
