| gauchobravo |
| Posted: Feb 24 2003, 04:37 AM |
I downloaded VD 1.5.1 build15654 for P4 I´m on Win200
VD only shows the original filters list. If I go "Load" and select 3rd party filter, everything is ok. I can also use those filter with no problem
But if I close VD and open again, all the 3rd party filters are gone. Only VD original filters are shown. I have to go thtu the "Load filter one by one" again and again
I have all files on the same directory, and all files "read-only" is off
Thanks 4 your support!
| ChristianHJW |
| Posted: Feb 24 2003, 02:44 PM |
Hmmm .... sorry, i have no idea whats wrong
| valja |
| Posted: Feb 24 2003, 04:22 PM |
All these filters must be in the subfolder \plugins with all other *.vdf files.
If they are there, aren't they *.dll filters? If they are dll files, VDub doesn't load them automatically. Just rename them from *.dll to *.vdf and they will be loaded automatically.
| gauchobravo |
| Posted: Feb 26 2003, 03:13 AM |
Valja that´s exactly the solution to this problem. All filters must be in the plugin subdir. When you install Vdub this folder is not created, and if you place the filters on root folder, then they are not remembered. In order to be remembered all filters mus be in the subdir. Thank you!!!!!!!!!! |
