Fcchandler Wmv Plugin 2.8 - Intro.wmv
Dstruct
  Posted: Mar 18 2012, 01:30 PM
Windows XP SP3
c:\Windows\System32\oobe\images\intro.wmv
Doesn't playback in VirtualDub. Obviously some problem with the audio part:
The audio codec reported an error while decompressing audio data. Error code: 512 (ACMERR_NOTPOSSIBLE)
General
Complete name                  : C:\WINDOWS\system32\oobe\images\intro.wmv
Format                         : Windows Media
File size                      : 650 KiB
Duration                       : 5s 699ms
Overall bit rate               : 934 Kbps
Maximum Overall bit rate       : 1 022 Kbps
Movie name                     : xp test
Performer                      : Frank Kruz
Encoded date                   : UTC 2001-04-05 21:06:37.100
Comment                        : 10 FPS TEST
Video
Format                         : WMV1
Codec ID                       : WMV1
Codec ID/Info                  : Windows Media Video 7
Description of the codec       : Windows Media Video V7
Duration                       : 5s 700ms
Bit rate                       : 1 019 Kbps
Width                          : 640 pixels
Height                         : 480 pixels
Display aspect ratio           : 4:3
Frame rate                     : 10.000 fps
Bit depth                      : 8 bits
Bits/(Pixel*Frame)             : 0.332
Stream size                    : 709 KiB
Audio
Format                         : WMA
Format version                 : Version 2
Codec ID                       : 161
Codec ID/Info                  : Windows Media Audio
Description of the codec       : Windows Media Audio V7 -   0 kbps,  8 kHz, mono
Duration                       : 5s 699ms
Bit rate                       : 2 447 bps
Channel(s)                     : 1 channel
Sampling rate                  : 8 000 Hz
Bit depth                      : 16 bits
Stream size                    : 1.70 KiB (0%)
Can this get fixed in the plugin?
wsm-9t6
Posted: Mar 18 2012, 02:06 PM
Except for the audio part, the video in that file plays fine with VirtualDub (using ffdshow's VfW interface, FWIW).
Someone would have to write an ACTUAL "wma acm decompressor". The one that ships with Windows is a joke, and the so-called "DivX Audio" is just a hacked joke. ohmy.gif
Posted: Mar 24 2012, 02:23 AM
OK, that is weird... As far as I can tell this movie doesn't have audio! It has something in the audio track but I don't think it's WMA. I get the impression that there is a trick to this intro, because the audio that you are supposed to hear is in a separate file, C:\WINDOWS\System32\oobe\images\title.wma.
Note that after loading intro.wmv, you can load title.wma using the "Audio from other file" option, and this will get you something close to what Microsoft intended. smile.gif
2 replies since Mar 18 2012, 01:30 PM Track this topic | Email this topic | Print this topic
