Mpeg-2 Plugin V4.2 Not Supporting .ts, Doesn't even support my regular .mpg
gdvalle
Posted: Feb 5 2012, 12:03 PM
I had to go back from MPEG-2 v4.2 to v4.1.
I capture some movies thru my Cinergy usb DVB-T tner and Terratec HomeCinema software. I get a .mpg file and then I convert it to DivX using Virtualdub and FCCHandler's plugins.
No problem until MPEG-2 v4.2, that does not recognize my .mpg's any more.
I see that it does no longer support the trnsport streams, but I am almost sure tha my MPG's are true MPG's.
And, in any case, why not supporting TS's any more ?
When I capture an HD video, it comes as a .TS file, and usually I reworked it with the same tools; in conclusion, the support of TS streams is an useful feature.
Regards
Giovanni
ale5000
Posted: Feb 5 2012, 04:57 PM
The MPEG-2 input plugin has never supported the transport streams.
New VirtualDub forum
Posted: Feb 11 2012, 06:09 AM
It does not support Transport Streams, but it does support some unusual variations of Program Streams. I made some changes to that part of the code in version 4.2 and I might have broken it. I will look into it.
marcinkk
Posted: Feb 15 2012, 11:17 AM
I've also found some problems with 4.2 version. In the 1.9.11 my MPEG-2 files from LG recorder are imported, but there is no preview and when I'm starting conversion the VDub crashes. But when I press "play" the movie is visible. So I went back to the 4.1 in the VDub stable.
On the other hand ... everyhing works fine in the VirtualDub 1.10.1 with the 4.2 version of MPEG-2 plugin.
gdvalle
Posted: Feb 25 2012, 04:22 PM
I tried MPEG2 plugin v.4.4 (appears as v.4.3 inside) and it regularly opens my mpg's.
B.T.W., my VITUALDUB is v.1.9.11.
Thanks, mr. FccHandler.
Posted: Feb 25 2012, 05:13 PM
Oops you're right, it still said v4.3 inside. I've fixed it now:
http://fcchandler.home.comcast.net/Plugins/MPEG2
5 replies since Feb 5 2012, 12:03 PM Track this topic | Email this topic | Print this topic
