Plugins64 With 32-bit Virtualdub?, Does this work with a 64-bit processor?
jsallen
Posted: Dec 5 2011, 06:04 PM
My computer has a 64-bit CPU but I am running the 32-bit version of VirtualDub because some plugins I use, notably Deshaker, are available only in a 32-bit version.
Other plugins are available in 64-bit versions -- notably so, the ones to input files in .MOV, .WAV, WMV, .FLV formats, etc.
Instructions provided with these plugins say to create a plugins64 subfolder under the VirtualDub folder, and put the plugins there. I don't see any information though on whether these plugins are compatible with the 32-bit version of VirtualDub. Are they? If so, is there any advantage in using them when the computer has a 64-bit CPU? (Might be faster with the added bit depth...)?
Also if so should I delete the corresponding 32-bit versions?
And -- I already have two plugins folders -- "plugins" and "plugins32". Are different 32-bit plugins specific to these folders or may they be installed in either one?
ale5000
Posted: Dec 5 2011, 06:28 PM
"plugins" is just a legacy folder, just rename it to plugins32.
32-bit filters/plugins must go in the plugins32 folder while 64-bit filters/plugins must go in the plugins64 folder.
32-bit filters/plugins can be used only by 32-bit VirtualDub while 64-bit filters/plugins can be used only by 64-bit VirtualDub.
You can have a 64-bit CPU but it doesn't matter at all if you have a 32-bit Windows.
On a 64-bit Windows you can use both 32 and 64-bit VirtualDub.
On a 32-bit Windows you can use only 32-bit VirtualDub.
The list of input plugins is here: http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
New VirtualDub forum
1 replies since Dec 5 2011, 06:04 PM Track this topic | Email this topic | Print this topic
