Please Help A Complete Mfc Weenie, Need Help With User Configuration
Chien_Andalusia
  Posted: Feb 20 2003, 12:31 AM
I'm not sure if this is the right forum, but here we go anyway.
I am in the process of developing a number of VirtualDub filters. In one of the filters I want a dialog box to open when a filter is selected from the menu within VirtualDub. In the dialog box I want a single text line where a user can type in some string. Once the "ok" button is pressed the string is stored to a variable.
Another possibility is for a dialog box to open up and request a user to select (for example) a text file by clicking a browse button and selecting the files in question by browsing the computer. I would like to be able to store the file path to a variable.
Finally ,while a video and a filter are selected within VirtualDub, is it possible for that filter to output data onto a pop-up dialog box as the video is playing? If so how would I go about it?
I have tried the example of reading user input contained in the SDK and have created a dialog box with check boxes that alters a video differently depending which box is checked. The trouble is my knowledge when it comes to all matters MFC are poor to say the best and I would not know how to make simple modifications to allow for different types of user input. I have visited MSDN and have ended up pretty confused. I can "draw" various dialog boxes from within Visual C++ without much problem at all. The problem arises when it comes to coding them (if you pardon the expression) to do "stuff".
I just hope I'm making some sense to someone out there and if anybody could possibly help me with any of my problems in some small way I would be very grateful.
Posted: Feb 20 2003, 02:19 AM
I'm totally confused by MFC myself. Have you tried regular old C++?
I'm afraid your questions are a bit too general. It's true that MSDN is the best resource for everything related to Windows programming, but it would probably help you a lot just to download other people's filter source code and see how they do their "stuff."
Chien_Andalusia
Posted: Feb 22 2003, 03:37 PM
So how do you make a dialog box pop up in regular old C++. If that is all I have to do then I will be rather happy.
Kippesoep
Posted: Feb 22 2003, 06:15 PM
Design your dialog box using the dialog box editor and call the "DialogBox" function using the appropriate parameters. You can find the necessary info in MSDN.
Chien_Andalusia
Posted: Feb 22 2003, 10:50 PM
Thanks for that link, I was looking in all the wrong places in MSDN it seems. I'll give it a shot.
ChristianHJW
Posted: Feb 24 2003, 02:43 PM
Please allow me to welcome you here, a Virtualdub filter developer is always more than welcome here biggrin.gif !!
5 replies since Feb 20 2003, 12:31 AM Track this topic | Email this topic | Print this topic
