Prefetching Multiple Source Frames In Vdub.
diablo23q
Posted: Jul 18 2011, 01:32 PM
Hi everyone,
Need some help. Could someone explain me how to deal with prefetchProc2 and mpInputFrames/mpOutputFrames arrays? A small example would be great.
Thank you.
Posted: Jul 24 2011, 02:33 AM
Use the prefetcher object passed to prefetchProc2 to request the source frames that you want.
In runProc, the requested source frames appear in the order you requested them in the mpInputFrames array. Process those into the buffer pointed to by mpOutputFrames[0].
diablo23q
Posted: Jul 24 2011, 02:44 PM
So prefetchProc2 will simply look like:
bool prefetchProc2(const VDXFilterActivation *fa, const VDXFilterFunctions *ff, sint64 frame, IVDXVideoPrefetcher *prefetcher) {
prefetcher->PrefetchFrame(0, frame, 1);
prefetcher->PrefetchFrame(0, frame + 1, 2);
return true;
And in runProc I can get this frames via fa->mpSourceFrames[0] and fa->mpSourceFrames[1] ?
Posted: Jul 31 2011, 11:50 PM
Yup. You don't need to set the cookie value to 1 and 2 respectively, though, if you're not actually going to use it. No matter what you set those to, you would always receive #frame in element [0] and #frame+1 in element [1].
diablo23q
Posted: Aug 3 2011, 08:27 PM
I think I'm doing something wrong sad.gif Frame in mpInputFrames[0] is always correct, but in other elements I get some random trash. For example following runProc crashes:
int runProc(const VDXFilterActivation *fa, const VDXFilterFunctions *ff) {
PixDim w, h;
const VDXFBitmap& frame0 = *fa->mpSourceFrames[0];
const VDXFBitmap& frame1 = *fa->mpSourceFrames[1];
const Pixel32 *src = (Pixel32 *)frame0.data;
const Pixel32 *src2 = (Pixel32 *)frame1.data;
Pixel32 *dst = (Pixel32 *)fa->mpOutputFrames[0]->data;
h = frame0.h;
do {
       w = frame0.w;
       do {
               *dst++ = ((*src++) + (*src2++))/2;
       } while(--w);
       src = (Pixel32 *)((char *)src + frame0.modulo);
       src2 = (Pixel32 *)((char *)src2 + frame1.modulo);
       dst = (Pixel32 *)((char *)dst + fa->mpOutputFrames[0]->modulo);
   } while(--h);
   return 0;
Where did I go wrong?
jpsdr
Posted: Aug 4 2011, 08:05 AM
You use old format/information wich are not valid with new structure.
Correct use would be :
sint32 h,w;
const VDXPixmap& frame0 = *fa->mpSourceFrames[0]->mpPixmap;
const VDXPixmap& frame1 = *fa->mpSourceFrames[1]->mpPixmap;
// Only if you are in RGB32 mode, otherwise, other planes are on data2 and data3 on YCbCr mode.
// Horizontal is /2 if you are on YUYV or UYVY mode. Warning !!!
// Get information from frame0.format to check the color mode.
Pixel32 *dst = (Pixel32 *)fa->mpOutputFrames[0]->mpPixmap->data
// Modulo doesn't exist anymore on this new structure, only pitch.
// Also, for other planes, there is pitch2 and pitch3.
for (h=0, h<frame0.h, h++)
 for (w=0, w<frame0.w, w++)
   dst[w]=(src[w]+src2[w])>>1;
 src=(Pixel32 *)((char *)src + frame0.pitch);
 src2=(Pixel32 *)((char *)src2 + frame1.pitch);
 dst=(Pïxel32 *) ((char *)dst + fa->mpOutputFrames[0]->mpPixmap->pitch);
return 0;
diablo23q
Posted: Aug 5 2011, 10:04 AM
Thanks, it works! Just one more question and I'll be satisfied. To be clear I'm writing deinterlacer and need to double video frame rate. How can I do this using mpOutputFrames or somewhat else? Tanks again, it really helps.
jpsdr
Posted: Aug 5 2011, 02:40 PM
Argh... Sorry, i have no idea for this one.
Get the latest source code (1.10.1-test12), and :
- Take a look at the code of filtres like IVTC and deinterlace.
- Read SDK.
Combining both, you may find out how things work.
Posted: Aug 5 2011, 02:46 PM
this is my sourcecode for an internal vdub double framerate filter in my modified virtualdub
should be easy enough to modify
#include "stdafx.h"
#include <vd2/system/cpuaccel.h>
#include <vd2/system/vdstl.h>
#include <vd2/system/fraction.h>
#include <vd2/system/memory.h>
#include <vd2/VDXFrame/VideoFilter.h>
#include <vd2/VDLib/Dialog.h>
#include <vd2/Kasumi/pixmap.h>
#include <vd2/Kasumi/pixmaputils.h>
#include <intrin.h>
#include <emmintrin.h>
#include "resource.h"
#include "filter.h"
class VDVideoFilter_fps_doublerate : public VDXVideoFilter {
public:
uint32 GetParams();
void Start();
void Run();
bool Prefetch2(sint64 frame, IVDXVideoPrefetcher *prefetcher);
//VDXVF_DECLARE_SCRIPT_METHODS();
protected:
bool mActive;
//VDXVF_BEGIN_SCRIPT_METHODS(VDVideoFilter_fps_doublerate)
//VDXVF_DEFINE_SCRIPT_METHOD(VDVideoFilter_fps_doublerate, ScriptConfig, "iii")
//VDXVF_DEFINE_SCRIPT_METHOD2(VDVideoFilter_fps_doublerate, ScriptConfig, "iiii")
//VDXVF_END_SCRIPT_METHODS()
uint32 VDVideoFilter_fps_doublerate::GetParams() {
const VDXPixmapLayout& srcLayout = *fa->src.mpPixmapLayout;
if (srcLayout.format ==255  )
 return FILTERPARAM_NOT_SUPPORTED;
VDFraction fr(fa->dst.mFrameRateHi, fa->dst.mFrameRateLo);
 double frConv=fr.asDouble();
fr *= VDFraction(2, 1);
fa->dst.mFrameRateHi = fr.getHi();
fa->dst.mFrameRateLo = fr.getLo();
fa->dst.mFrameCount = ((fa->dst.mFrameCount )<<1);
mActive=true;
fa->dst.mpPixmapLayout = fa->src.mpPixmapLayout;
return  FILTERPARAM_SUPPORTS_ALTFORMATS;
bool VDVideoFilter_fps_doublerate::Prefetch2(sint64 frame, IVDXVideoPrefetcher *prefetcher) {
 prefetcher->PrefetchFrame(0, frame>>1  , 0);
return true;
void VDVideoFilter_fps_doublerate::Run() {
const VDXPixmap *pxsrc[1]={
const VDXPixmap& pxdst = *fa->mpOutputFrames[0]->mpPixmap;
fa->dst.pitch = fa->src.pitch;
fa->dst.offset  = fa->src.offset;
void VDVideoFilter_fps_doublerate::Start() {
extern const VDXFilterDefinition filterDef_fps_doublerate =
VDXVideoFilterDefinition<VDVideoFilter_fps_doublerate>(
 NULL,
//  "half rate",
 "fps double",
 "Doubles frame rate");
// warning C4505: 'VDXVideoFilter::[thunk]: __thiscall VDXVideoFilter::`vcall'{24,{flat}}' }'' : unreferenced local function has been removed
#pragma warning(disable: 4505)
diablo23q
Posted: Aug 6 2011, 12:58 AM
diablo23q
Posted: Feb 22 2012, 02:44 PM
And finally - http://forums.virtualdub.org/index.php?act...=ST&f=7&t=20890
10 replies since Jul 18 2011, 01:32 PM Track this topic | Email this topic | Print this topic
