| JPT |
| Posted: Jul 7 2011, 02:35 PM |
I muxed a VC1 and an AC3 track using mkvmerge GUI 4.8.0 into a matroska file. (since i wasn't able to open the VC1 directly in vdub) Then I opened it in vdub. After successful import it showed only garbage. Moving the Frame-Slider chrashed vdub.
Missing codecs?
vdub 1.9.11 matroska filter 3.0
I do not want to post the whole crash report, since there seems to be no way to attach files. So i'll add only what I believe is the most important. if you need any more info...
| CODE | Thread call stack: 03392262: SCLS!DriverProc [03390000+1328+f3a] 033937ed: SCLS!DriverProc [03390000+1328+24c5] 0339a8f3: SCLS!DriverProc [03390000+1328+95cb] 0339a89f: SCLS!DriverProc [03390000+1328+9577] 03391dd4: SCLS!DriverProc [03390000+1328+aac] 10009265: Matroska!VDGetPluginInfo [10000000+4030+5235] 0339147b: SCLS!DriverProc [03390000+1328+153] 75ec18a8: MSVFW32!ICSendMessage [75ec0000+187d+2b] 75ec4c4d: MSVFW32!ICDecompress [75ec0000+4c10+3d] 1000840a: Matroska!VDGetPluginInfo [10000000+4030+43da] 100085be: Matroska!VDGetPluginInfo [10000000+4030+458e] 004d4034: VDVideoSourcePlugin::streamGetFrame() 0043360a: VDFilterFrameVideoSource::RunRequests() 5d468659: COMCTL32!DefSubclassProc [5d450000+184f1+168] 77d18709: USER32!GetDC [77d10000+8697+72] 004619f6: VDProject::UpdateFrame() 00432855: VDFilterFrameRequest::CreateClient() 0043289d: VDFilterFrameRequest::CreateClient() 00431bb2: VDFilterFrameManualSource::CreateRequest() 0043c92b: FilterSystem::RequestFrame() 00462752: VDProject::DisplayFrame() 00460b28: VDProject::MoveToFrame() 004672f3: VDProjectUI::OnPositionNotify() 0046d85a: VDProjectUI::MainWndProc()
| ale5000 |
| Posted: Jul 7 2011, 04:01 PM |
You should post the whole crash report and maybe also the video that cause the crash (it is better if you find a small video that cause the crash).
| JPT |
| Posted: Jul 8 2011, 10:22 AM |
Ok, another try, similar crash: (i did the remuxing for testing the mkv plugin only)
- recorded from DVB-S using vcr.net - demuxed using project X - cut using cuttermaran - mux to mpeg ps using mplex (up to date version! compiled it a week ago) - remux to mkv using mplextools Mkvmerge GUI. - open with vdub.
Same problems. It does not recognize the codec. Shows garbage only. Do some scrolling and it will crash.
So this time we have MPEG2 Video and MPEG 1 Layer 2 Audio.
fcchandler statet "The Matroska plugin allows you to open most Matroska files..." So does he speak of H264 codec only? If so, maybe the filter should check the codec and print a warning.
Report of this crash:
| CODE | VirtualDub crash report -- build 32842 (release) --------------------------------------
Disassembly: 017821e0: ff8b5d08c703 dec dword ptr [ebx+3c7085d] 017821e6: 0000 add [eax], al 017821e8: 0000 add [eax], al 017821ea: 85c9 test ecx, ecx 017821ec: 0f868c010000 jbe 0178237e 017821f2: 8945b8 mov [ebp-48h], eax 017821f5: 8b450c mov eax, [ebp+0ch] 017821f8: 8975bc mov [ebp-44h], esi 017821fb: 8bda mov ebx, edx 017821fd: 8b75b8 mov esi, [ebp-48h] 01782200: 031cb8 add ebx, [eax+edi*4] 01782203: 3bf3 cmp esi, ebx 01782205: 0f826b010000 jc 01782376 0178220b: 8bd3 mov edx, ebx 0178220d: 47 inc edi 0178220e: 8b7508 mov esi, [ebp+08h] 01782211: 893e mov [esi], edi 01782213: 3bf9 cmp edi, ecx 01782215: 72e4 jc 017821fb 01782217: 8b75bc mov esi, [ebp-44h] 0178221a: 8b450c mov eax, [ebp+0ch] 0178221d: 031cb8 add ebx, [eax+edi*4] 01782220: 8b4510 mov eax, [ebp+10h] 01782223: 8b38 mov edi, [eax] 01782225: 8975e0 mov [ebp-20h], esi 01782228: 8955e4 mov [ebp-1ch], edx 0178222b: 897de8 mov [ebp-18h], edi 0178222e: 8b560c mov edx, [esi+0ch] 01782231: 8955ec mov [ebp-14h], edx 01782234: 8b45e4 mov eax, [ebp-1ch] 01782237: f765ec mul eax, dword ptr [ebp-14h] 0178223a: f775e8 div eax, dword ptr [ebp-18h] 0178223d: 8d5001 lea edx, [eax+01h] 01782240: 8955b8 mov [ebp-48h], edx 01782243: 8b5604 mov edx, [esi+04h] 01782246: 8d440201 lea eax, [edx+eax+01h] 0178224a: 894604 mov [esi+04h], eax 0178224d: 8975f0 mov [ebp-10h], esi 01782250: 895df4 mov [ebp-0ch], ebx 01782253: 897df8 mov [ebp-08h], edi 01782256: 8b5e0c mov ebx, [esi+0ch] 01782259: 895dfc mov [ebp-04h], ebx 0178225c: 8b45f4 mov eax, [ebp-0ch] 0178225f: f765fc mul eax, dword ptr [ebp-04h] 01782262: f775f8 div eax, dword ptr [ebp-08h] <-- FAULT 01782265: 2b45b8 sub eax, [ebp-48h] 01782268: 3d00000001 cmp eax, 01000000 0178226d: 89460c mov [esi+0ch], eax 01782270: 732e jnc 017822a0 01782272: 8b5618 mov edx, [esi+18h] 01782275: 8b5e04 mov ebx, [esi+04h] 01782278: 8b4dc0 mov ecx, [ebp-40h] 0178227b: c1e208 shl edx, 08h 0178227e: 0fb639 movzx edi, byte ptr [ecx] 01782281: 0bd7 or edx, edi 01782283: 895618 mov [esi+18h], edx 01782286: c1e308 shl ebx, 08h 01782289: c1e008 shl eax, 08h 0178228c: 895e04 mov [esi+04h], ebx 0178228f: 41 inc ecx 01782290: 3d00000001 cmp eax, 01000000 01782295: 89460c mov [esi+0ch], eax 01782298: 72e1 jc 0178227b 0178229a: 894dc0 mov [ebp-40h], ecx 0178229d: 8b4d14 mov ecx, [ebp+14h] 017822a0: 8b4508 mov eax, [ebp+08h] 017822a3: 8b30 mov esi, [eax] 017822a5: 8b5518 mov edx, [ebp+18h] 017822a8: 8b7d0c mov edi, [ebp+0ch] 017822ab: 8b5d10 mov ebx, [ebp+10h] 017822ae: 0114b7 add [edi+esi*4], edx 017822b1: 8b03 mov eax, [ebx] 017822b3: 8d1402 lea edx, [edx+eax] 017822b6: 81fa00000100 cmp edx, 00010000 017822bc: 0f869d000000 jbe 0178235f 017822c2: 8b4510 mov eax, [ebp+10h] 017822c5: 33f6 xor esi, esi 017822c7: 85c9 test ecx, ecx 017822c9: c70000000000 mov dword ptr [eax], 00000000 017822cf: 0f868f000000 jbe 01782364 017822d5: 83f905 cmp ecx, 05h 017822d8: 7265 jc 0178233f 017822da: 8d59fb lea ebx, [ecx-05h] 017822dd: 8b4510 mov eax, [ebp+10h]
Built on Aegis on Fri Dec 24 13:18:44 2010 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 2]
EAX = c999a000 EBX = bddcc400 ECX = 00000004 EDX = 00000227 EBP = 0013f884 ESI = 01d80050 EDI = 00000176 ESP = 0013f83c EIP = 01782262 EFLAGS = 00210a13 FPUCW = ffff027f FPUTW = ffffffff
Crash reason: Integer Overflow
Crash context: An exception occurred in module 'SCLS'.
Pointer dumps:
ESI 01d80050: 00000000 618f07b7 00000000 bddcc400 00000000 00000000 62b37d2e 00000000 ESP 0013f838: 00000000 bbd4edb7 01d80050 00cdcda2 01d80048 00029af0 0013f8a8 01d80050 0013f858: bcf9632e 00000176 bddcc400 01d80050 00000172 00000176 bddcc400 01d80050 0013f878: 000002e8 00000176 bddcc400 01d80050 017837ed 0013f8a8 01d8e630 01d8e640 0013f898: 00000004 00000001 00cdcda2 000000b2 00000004 000000b5 000000df 000000c6 EBP 0013f880: bddcc400 01d80050 017837ed 0013f8a8 01d8e630 01d8e640 00000004 00000001 0013f8a0: 00cdcda2 000000b2 00000004 000000b5 000000df 000000c6 01c79b10 01d80048 0013f8c0: 01d80050 01d8e630 01d8e640 00cdcda2 00ac1090 01d80048 0013f97c 01c50020 0013f8e0: 0178a8f3 00cdcc39 01c50020 0013f97c 00cdcc38 0013f97c 01c50020 0178a89f
Thread call stack: 01782262: SCLS!DriverProc [01780000+1328+f3a] 017837ed: SCLS!DriverProc [01780000+1328+24c5] 0178a8f3: SCLS!DriverProc [01780000+1328+95cb] 0178a89f: SCLS!DriverProc [01780000+1328+9577] 01781dd4: SCLS!DriverProc [01780000+1328+aac] 10009265: Matroska!VDGetPluginInfo [10000000+4030+5235] 0178147b: SCLS!DriverProc [01780000+1328+153] 75ec18a8: MSVFW32!ICSendMessage [75ec0000+187d+2b] 75ec4c4d: MSVFW32!ICDecompress [75ec0000+4c10+3d] 1000840a: Matroska!VDGetPluginInfo [10000000+4030+43da] 100085be: Matroska!VDGetPluginInfo [10000000+4030+458e] 004d4034: VDVideoSourcePlugin::streamGetFrame() 0043360a: VDFilterFrameVideoSource::RunRequests() 5d468659: COMCTL32!DefSubclassProc [5d450000+184f1+168] 77d18709: USER32!GetDC [77d10000+8697+72] 004619f6: VDProject::UpdateFrame() 00432855: VDFilterFrameRequest::CreateClient() 0043289d: VDFilterFrameRequest::CreateClient() 00431bb2: VDFilterFrameManualSource::CreateRequest() 0043c92b: FilterSystem::RequestFrame() 00462752: VDProject::DisplayFrame() 00462292: VDProjectTimelineTimingSource::GetNearestKey() 00460b28: VDProject::MoveToFrame() 00460c57: VDProject::MoveToNearestKey() 004672a0: VDProjectUI::OnPositionNotify() 0046d85a: VDProjectUI::MainWndProc() 77d194a7: USER32!GetWindowLongA [77d10000+947c+2b] 00465ac0: VDProjectUI::WndProc() 00479b65: VDUIFrame::StaticWndProc() 77d18709: USER32!GetDC [77d10000+8697+72] 77d187eb: USER32!GetDC [77d10000+8697+154] 77d1b743: USER32!GetParent [77d10000+b5d7+16c] 77d1e2f7: USER32!SendMessageA [77d10000+e2ae+49] 004b21db: VDPositionControlW32::Notify() 00518cdb: VDRoundToInt64() 004b2d78: VDPositionControlW32::WndProc() 004b32a2: VDPositionControlW32::StaticWndProc() 77d18709: USER32!GetDC [77d10000+8697+72] 77d187eb: USER32!GetDC [77d10000+8697+154] 77d189a5: USER32!GetWindowLongW [77d10000+887e+127] 77d1cff8: USER32!PeekMessageA [77d10000+cefd+fb] 77d1bccc: USER32!DispatchMessageA [77d10000+bcbd+f] 00452596: WinMain@16() 005b78db: __tmainCRTStartup() 7c816d4f: kernel32!RegisterWaitForInputIdle [7c800000+16d06+49]
| ale5000 |
| Posted: Jul 8 2011, 03:22 PM |
It support a lot of formats including MPEG2 Video, MPEG 1 Layer 2 Audio, AC3 Audio (I'm not sure about VC1) and usually doesn't crash when you open a format that it doesn't support.
If you upload the file (for example to http://www.multiupload.com/) and post the link here, fcchandler will be able to fix the problem faster.
| Matrosko |
| Posted: Jul 9 2011, 01:32 PM |
Wich version of matroska is used on the muxed file? Something like:| CODE | Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58 Writing library : libebml v1.2.0 + libmatroska v1.1.0 |
From 4.1.0 header compression is set by default. Remove it from option tab.
http://www.bunkus.org/videotools/mkvtoolni...val_compression |
| Posted: Jul 9 2011, 02:41 PM |
The Matroska input plugin supports header removal compression, so that's not the problem.
The crash is not in VirtualDub or the Matroska plugin, but in a module identified as "SCLS". It has a DriverProc function, which hints that it might be a codec. That's about all I can see in the crash dump, but your description of the behavior definitely points to a codec problem. What video codecs and/or packages have you installed?
FWIW, I am using ffdshow tryouts Beta 7. Good stuff.
I have not tested VC1 in Matroska so I don't know whether the plugin will work with it or not. I have tested MPEG-2 in Matroska and it should work.
| ale5000 |
| Posted: Jul 9 2011, 04:14 PM |
@JPT: In VirtualDub look at File => File information to see what video/audio codecs are used.
| Matrosko |
| Posted: Jul 9 2011, 05:23 PM |
| QUOTE (fccHandler @ Jul 9 2011, 02:41 PM) | The Matroska input plugin supports header removal compression, so that's not the problem.
I have not tested VC1 in Matroska so I don't know whether the plugin will work with it or not. I have tested MPEG-2 in Matroska and it should work. |
smart ppl here  So this filter doesnt work alone. Also needs haali splitter? It is possible to save the parsing like an index file and skeep every time the pharsing of that file? |
| ale5000 |
| Posted: Jul 9 2011, 05:32 PM |
@Matrosko: No, it doesn't need any splitter to be used from VirtualDub.
PS: From a fast test VC1 in Matroska seems to works fine.
| Posted: Jul 9 2011, 09:30 PM |
Google search says SCLS.DLL is the MSU Screen Capture Lossless Codec. That doesn't sound like something that should be activating with VC-1 data. |
| JPT |
| Posted: Jul 10 2011, 10:18 AM |
Wow. So many answers. Thanks!
I just tried the MKV again, and now it works. Uses ffdshow (WVC1). I tinkered with the ffdshow config recently, making it default for a few addional codec IDs. So, seems the problem wasn't the muxing at all, but the MSU codec. They have great software, but it often seems to be rather instable. I should remove it.
The matroska plugin works well with the VC1 codec but initially shows a green screen.
The MPEG2 Video showing garbage is because of the MSU codec, too. Removing the MSU codecs results in showing "Missing Codec" in vdub. Wow. That's how software should report problems. Great work, fcchandler! Changed the ffdshow settings again: and it works! But there again is a green screen after startup of vdub. seems to be a ffdshow problem. Got fddshow tryouts rev 3866 of May 2011
Ok, next time I have problems like this, I know how to handle them
Thank you very much for your help!
JPT |
| JPT |
| Posted: Jul 10 2011, 01:01 PM |
The green actually *is* a problem. I tried to compress 3 times, using different start frames. - once I got green frames at frame 2 to 4 - 2 - 2 and 3
any idea where this comes from?
Using a different codec (lagarith), it's frame 0 and 1.
ps. the green frame really is in the output. Tried the avi on a hardware player, too. |
| ale5000 |
| Posted: Jul 10 2011, 05:24 PM |
You can avoid green frames by using x264vfw and Xvid to decode H.264 and Xvid videos instead of ffdshow-tryouts.
