Minor Changes To The Quicktime Input Plugin
ale5000
Posted: Mar 3 2011, 07:21 PM
This is the thread for the modded version of the tateu's QuickTime plugin.
Consider it beta.
Changelog:
0.2.0.3
- More clear message when the QuickTime framework is missing
- Minor changes
0.2.0.2b
- Added the possibility to compile a 64-bit build (only for vc8 and vc9)
Note: Currently can't be used since the QuickTime SDK don't support 64-bit on Windows
0.2.0.2
- Now it open also these extensions: .3g2 .qt .mp4v .m4a .m4r (and some other annoying extensions used by Apple)
- Minor changes
0.2.0.1
- Now it appears also under Audio => Audio from other file...
- Now it open also these extensions: .hdmov .nsmov .m4v .f4v .3gp .3gpp
- In File => File Information... now it say "QuickTime" instead of "AVI"
- Minor changes
Modded version (0.2.0.3) => http://www.mediafire.com/?ece9mh32fv5dpk2
Original version (0.2.0.0) => http://www.tateu.net/software/
Note: If you open a .f4v file with the H.264 decoder enabled in ffdshow VFW it will crash, if you disable it then it will work. x264vfw is ignored completely.
New VirtualDub forum
ale5000
Posted: Mar 8 2011, 04:18 AM
Edit: Post removed
jonbondy
Posted: Mar 11 2011, 01:08 AM
I tried reading an MOV file using this plugin, and only the first half of the movie appears to be available to VirtualDub. Any idea when this could be fixed?
Thanks!
ale5000
Posted: Mar 11 2011, 01:28 AM
I'm not the author (I just made minor changes) and the author have stopped working on it, so if there isn't any voluntary developer noone will fix it.
tateu
Posted: Mar 14 2011, 06:23 AM
I'd like to get back to it someday...I use the AviSynth version and so I kind of forgot to try and keep the VirtualDub version up to date.
ale5000
Posted: Mar 14 2011, 09:53 PM
@tateu: I'm glad that you are still interested in it, the most important thing that should be done is to make it compatible with ffdshow-tryout and x264vfw for the H.264 format.
ale5000
Posted: Mar 14 2011, 11:20 PM
Edit: Post removed
ale5000
Posted: Mar 22 2011, 02:39 PM
New version + sources on the first post.
Jim_pansen
Posted: Nov 16 2011, 09:53 PM
ProRes files created by FFMPEG can't be loaded with the plugin.
QT has no issues. Can this be corrected?
Cheers
Jim
ale5000
Posted: Dec 4 2011, 04:43 PM
QUOTE (Jim_pansen @ Nov 16 2011, 10:53 PM)
Cheers
Jim
Probably you will have better results with this plugin: http://forums.virtualdub.org/index.php?act...=ST&f=7&t=20317
Try if it works with your files and report back in the thread.
9 replies since Mar 3 2011, 07:21 PM Track this topic | Email this topic | Print this topic
