Change Sub Color, How to change the color of the subtitles
pauldapigeon
Posted: Mar 3 2011, 03:04 PM
Hi!
I've been using virtualdub for a while, though, I've only embeded some subs. At one point I think I changed sub colors and now subtitles are always yellow, no matter what filter I use for them and I can't remember how to change it back.
Any ideas how to solve this problem?
Placio74
Posted: Mar 3 2011, 05:02 PM
VideoAudio
What subtitle format?
pauldapigeon
Posted: Mar 3 2011, 05:50 PM
Sub Station Alpha
Placio74
Posted: Mar 4 2011, 11:44 AM
VideoAudio
If you do not know how to manually correct font color in SSA/ASS subtitles... use Aegisub editor (look at Styles Manager).
BTW
Which plugin You are using? Subtitler or TextSub?
pauldapigeon
Posted: Mar 5 2011, 12:57 AM
it happens with both
Placio74
Posted: Mar 5 2011, 03:41 PM
VideoAudio
Subtitler and TextSub (VSFilter) should display font color, which is defined in SSA/ASS subtitles.
Tried to edit style in Aegisub?
BTW
What program created (or convert) Your subtitles? Subtitle Workshop or...?
pauldapigeon
Posted: Mar 7 2011, 07:00 PM
I don't know what created the subtitles, I just downloaded them from the internet in English and translated them in divxland media subtitler.
About aegisub, I tried it, and it says the color saved in the subtitle is white, so the problem has a different source.
ale5000
Posted: Mar 7 2011, 07:06 PM
The faster way is open the subtitle file with notepad and "manually" look at it biggrin.gif
New VirtualDub forum
Placio74
Posted: Mar 7 2011, 08:15 PM
VideoAudio
Ehm... I check and DivXLand Media Subtitler sets yellow font color (65535) as default in SubStation Alpha subtitles format (this can be changed in configuration).
For white color should be 16777215 (in SSA).
In Advanced SubStation Alpha format for white color should be &H00FFFFFF.
Show us styles of these subtitles ([V4+ Styles] section).
pauldapigeon
Posted: Mar 15 2011, 06:31 PM
thanks, haven't checked back in a while, but this last bit of advice worked
9 replies since Mar 3 2011, 03:04 PM Track this topic | Email this topic | Print this topic
