Frame Rate Doubling Using Sdk, Best Practice?
xinu
Posted: Nov 24 2009, 08:50 PM
I'd like to double the output frame rate only using VDPluginSDK-1.1, deriving from the VDXVideoFilter class.
I've tried the following in the GetParams() method, after perusing the internal fieldbob2 source code:
fa->dst.mFrameRateHi *= 2;
if (fa->dst.mFrameCount >= 0)
 fa->dst.mFrameCount *= 2;
But the fa->src->mFrameNumber in the Run() method keeps incrementing by 1 per call. I expected the Run() to be called twice per dst (?)
What is the recommended way to handle this?
Cheers!
Posted: Nov 25 2009, 06:20 AM
Hmm, I can't reproduce this. Here's my hacky test filter:
#include <crtdbg.h>
#include <vd2/VDXFrame/VideoFilter.h>
#include <vd2/VDXFrame/VideoFilterEntry.h>
class Filt : public VDXVideoFilter {
public:
uint32 GetParams() {
 return 0;
void Run() {
 _RPT2(0, "frame %d -> %d\n", (int)fa->src.mFrameNumber, (int)fa->dst.mFrameNumber);
VDXVideoFilterDefinition<Filt> g_filter("double", "foo", "bar");
VDX_DECLARE_VFMODULE()
VDXFilterDefinition *VDXGetVideoFilterDefinition(int index) {
if (!index--) { return &g_filter; }
return NULL;
This is the output it produces when I step through frames:
frame 0 -> 0
frame 0 -> 1
frame 1 -> 2
frame 1 -> 3
frame 2 -> 4
frame 2 -> 5
frame 3 -> 6
frame 3 -> 7
frame 4 -> 8
frame 4 -> 9
frame 5 -> 10
frame 5 -> 11
frame 6 -> 12
frame 6 -> 13
xinu
Posted: Nov 25 2009, 08:21 AM
Thanks, but when using Prefetch2, it appears I need to override the Prefetch too (the GetParams is as you specified):
sint64 MyFilter::Prefetch(sint64 frame)
   return frame >> 1; // This does the trick of framerate doubling with Prefetch2
bool MyFilter::Prefetch2(sint64 frame, IVDXVideoPrefetcher *prefetcher)
prefetcher->PrefetchFrame(0, Prefetch(frame) - 1, 0); // Prev
prefetcher->PrefetchFrame(0, Prefetch(frame), 0); // Curr
prefetcher->PrefetchFrame(0, Prefetch(frame) + 1, 0); // Next
return true;
void MyFilter::Run()
   logMessage(str(format("  prev=%d") % fa->mpSourceFrames[0]->mFrameNumber));
   logMessage(str(format("  curr=%d") % fa->mpSourceFrames[1]->mFrameNumber));
   logMessage(str(format("  next=%d") % fa->mpSourceFrames[2]->mFrameNumber));
   logMessage(str(format("  dest=%d") % fa->dst.mFrameNumber));
Is this by design? (using version 1.9.7)
Posted: Nov 26 2009, 03:33 AM
No, you only need to override Prefetch2. You also shouldn't need to call Prefetch() from Prefetch2(), which if you were doing before would have been the source of your problem. Prefetch() is a routine you optionally provide, and if you were calling it, you were invoking the stub implementation in VDXVideoFilter instead.
3 replies since Nov 24 2009, 08:50 PM Track this topic | Email this topic | Print this topic
