Edge Line Replacer, Does one already exist?
Darkfalz
Posted: Jan 30 2003, 01:31 PM
Often on video captures you often get a distorted/black line right on edges of video (not VCR head noise) and it'd be nice if there was a filter just to trim it off (that kind of thing can really chew bits) and replace it with the nearest adjacent line. To trim the line and resample the entire thing is both slow and you unneccesarily lose video quality that way.
outlyer
Posted: Jan 30 2003, 10:35 PM
Spanish Section Mod
I don't understand what you're saying unsure.gif but why are you talking about resampling? if there's noise in the edge, cropping it should be enough. (Excuse if I misunderstood you completely tongue.gif)
Darkfalz
Posted: Jan 31 2003, 03:30 AM
Say you have a capture off TV at 320x240 with just one line on the right edge black. If you trim that line off, you'll have a video of 319x240 which is not suitable for compression. If you resampled that video, it'd take a while to process and you'd lose quality resizing the whole thing just for one line.
My suggestion is you take the nearest line on that edge and use that to replace the black line. So you'll get one repeated line, but it's on the edge there so you probably wont notice. You've still got your original size and you didn't have to resize anything.
Posted: Jan 31 2003, 03:50 AM
If that's the case, then you could use the resize filter as follows:
New width = 319
New height = 240
Filter mode = Nearest neighbor
check "Expand frame and letterbox image"
Frame width = 320
Frame height = 240
Fill color = (your choice)
Darkfalz
Posted: Feb 1 2003, 12:01 PM
QUOTE (fccHandler @ Jan 30 2003, 09:50 PM)
New width = 319
New height = 240
Frame width = 320
Frame height = 240
Um, did you even read what I posted? I don't want any solid colour to replace that line, I want the line directly next to it copied over it.
I found a filter which is meant to do this but unfortunately it's bugged (and very slow). Border Control by Simon Waters.
outlyer
Posted: Feb 1 2003, 02:21 PM
Spanish Section Mod
Why doubling a line is better than adding a black one?
outlyer
Posted: Feb 1 2003, 02:23 PM
Spanish Section Mod
I know that a single black line will put block based codecs into some problems but despite this, a black line at the edge will be less noticeable, or so I think
jcsston
Posted: Feb 1 2003, 06:34 PM
Matroska Dev
QUOTE (Darkfalz @ Feb 1 2003, 06:01 AM)
New width = 319
New height = 240
Frame width = 320
Frame height = 240
You could use a Nearest neighbor resize to 320x240
that would duplicate one line of pixels but the pixels would probably be in the middle of the picture wink.gif
Use the Matroska file format
Posted: Feb 1 2003, 11:02 PM
The resize filter works according to OpenGL mapping, so yes, you will get the duplicate column right in the center of the image.
A nasty solution to this is to add borders around the image, crop it to 638x240 with the image on the left side, resize that to 640x240, and then crop that back down to 320x240.
Darkfalz
Posted: Feb 2 2003, 04:27 PM
QUOTE (phaeron @ Feb 1 2003, 05:02 PM)
Or you could just tell me the two or three lines of code to use in Filter Factory wink.gif
I really don't understand what the point of releasing that was with absolutely no documentation. How do you expect people to know what codes they can use?
jcsston
Posted: Feb 2 2003, 07:08 PM
Matroska Dev
Here is phaeron's previous answer about Filter Factory
Posted: Feb 2 2003, 10:41 PM
I released the source code. Not satisfied with that? You'll have to live with the fact that not everything I put out is a finished product. Sometimes I just release stuff in case someone else might find it useful.
Darkfalz
Posted: Feb 3 2003, 05:31 AM
QUOTE (phaeron @ Feb 2 2003, 04:41 PM)
I looked through the source code for the constructors and couldn't find them. I guess I didn't look hard enough.
12 replies since Jan 30 2003, 01:31 PM Track this topic | Email this topic | Print this topic
