Symptoms: while processing a file using subtitle filter, the program freezes on specific frame, causing CPU Usage to 100% and the process can't be aborted.
Resolution: Killing virtualdub process from ProcessExplorer or something.
Description and measures taken: 1. Tryed to encode the file without any filter (as everyone should do), and the mention problem does not appear Result: file is encoded correctly
2. Tryed to inspect the log file Result: file reports begining of the dub process - this is the last line
3. Tryed to load a different .ssa file (rather those causing the problem) Result: file encoded correctly
4. Tryed to determine the location, phrase and options set in the .ssa file causing the problem Result: this reveals some more questions...
After some black-box search for the problem I have understand that a specific sequence of characters causes the program to freeze. After altering the lines containing the character sequence, the problem disappear. Look at the picture:
 red-framed line causes the freeze. Character set is ANSI (Windows-1251, I beleive) Language is Bulgarian, Cyrilic one Character sequence causing the problem is: ".\NŠī" Spelling: (full stop); (reversed solidus); (Latin Big letter N); (Cyrilic Big Letter ER); (Cyrilic Small Letter O) This is a link to a .ssa file which causes the problem at the time 2.85 seconds from the begining. Versions used: 1.6.7; 1.7.8; 1.8.0; 1.8.1 (test7) |
