Vvcrs2 Problem
i4004
Posted: Mar 10 2005, 01:29 AM
and i'm sure it's not the tuner problem, as i don't have tuner.
my signature:
Posted: Mar 10 2005, 02:13 AM
Um, do you mind telling us what you're doing?
i4004
Posted: Mar 10 2005, 04:07 AM
i decided to run desktop at full glorious b/w!
BTW, did you notice that was your 1337 post!
<blush>
i'm not really doing anything; i fire up vvcrs2, set times, and it starts vdub....with this error.
i dunno what is vvcrs trying to "open".
oh yeah;
http://vvcrs.asktech.ca/virtualdub.php
you try it too.
i didn't used too many words as leon wrote on the forum recently.
my signature:
Posted: Mar 10 2005, 06:01 AM
The error is bring thrown because a filename with spaces isn't being quoted. Here's what I'm getting on my end from GetCommandLineW():
/capture   /capfile  h:\foo\blah(2005-3-9 at 21-52-55).avi /capchannel 5 /capstart 59
i4004
Posted: Mar 10 2005, 11:39 PM
i actually thought it would be something like that, as i saw time-tag of vvcrs2 wasn't completed (brackets left unclosed).
i would suggest this to leon
/capture   /capfile  h:fooblah(2005-3-9@21-52-55).avi /capchannel 5 /capstart 59
i would also suggest vvcrs2 to use same time format as win uses; i have always found yyyy-m-d exactly the opposite to human way of thinking, so i just changed it to d.M.yyyy.
i mean, are we writing time as
55-52-21?
(what is the historic reason for that anyway?)
although that's a no problem anyway; there's a file date/time as a part of file-system itself, and i surely won't use the date/time tag as a filename when it gets to media burning phase.
my signature:
leoncheong
Posted: Mar 16 2005, 09:46 AM
OK. fixed. I'll keeping the format for it is the same as VirtualVCR.
i4004
Posted: Mar 16 2005, 08:53 PM
i tried it with 2 timers in a row, and it seems to be working fine now.
thanks.
ps. i just tried 6 timers in a row, and it went fine.
my signature:
6 replies since Mar 10 2005, 01:29 AM Track this topic | Email this topic | Print this topic
<< Back to Capture
