Vdub 1.6.4 Tuner Settings, cinergy 600 Tuner problems
frank10
Posted: Feb 19 2005, 10:35 AM
Hi to all.
I have a Terratec Cinergy 600 tv card and I installed VirtualDub 1.6.4 that can handle WDM drivers to record tv at 720x576. It works fine, but I have this problem:
Every time I start virtualdub, I must go to Tuner settings and select antenna instead of cable to select some tv channel. Is there a way to save this setting?
And also it could be useful to order the channel after the auto scan.
Thanks
Francesco
Posted: Feb 19 2005, 10:25 PM
Nope, you can't save antenna/cable yet; I had hoped that the drivers would do that themselves but that's apparently not the case. I need to add some way to save arbitrary settings since I can't push them all out to the UI.
leoncheong
Posted: Mar 7 2005, 02:37 AM
Than is there any registory location that I can change?
I have a Videomater card and a PCTV card. Both gives me the same problem as frank10. I managed to find the location for the country code but not for antenna/cable settings. sad.gif
dhamn
Posted: Mar 16 2005, 08:56 AM
when i first installed virtualdub 1.6.4 all tuner settings were ok,
then i installed powervcr ii 3 and virtualdub had the same problem (tuner-settings always forgot the cable/antenna setting)
when i uninstalled powervcr the problem was still there.
but fortunatly i used the program easyclean before installing powervcr:
this program backups the registry and saves a dirlist of all files on your harddisk. after the install you can now compare all settings and list the changes made in the registry/harddisk.
i recoverd all registry-changes made by install/uninstall of powervcr using easyclean...
and guess what....
the compare result of the regsitry is about ~390kb big... so i can not post it here.
but i think its a config-problem of a other program...
i hope it helped...
3 replies since Feb 19 2005, 10:35 AM Track this topic | Email this topic | Print this topic
<< Back to Capture
