| CheeToS |
| Posted: Jun 18 2003, 02:48 PM |
Hey, when I try setting the resolution (Video>Format) to anything above 320x240, the video screen freezes & I only get audio until I change it back to 320x240 or lower. If I go above 640x480 I get the "Error 418: Unsupported Video Format" error, which is expected. I'm using a Pinnacle PCTV Pro, on Win2k SP3. Any help would be appreciated.
EDIT: Doh, wrong forum, sorry
| jcsston |
Posted: Jun 19 2003, 10:35 PM |
Matroska Dev
Topic moved to right forum
Are you using the WDM wrapper? This is an limitation of the wrapper and the only way around it is to use a WDM capture program, such as VirtualVCR.
Also, It could be that your capture card only supports capturing up to 320x240.
