| elbeardo69 |
| Posted: Dec 7 2002, 02:29 PM |
Hey,
Not used to struggling!!
Title says it all. File info gives tell me that the original avi uses DivX 4.0 Beta Codec. I'm trying to recompress and append the end of the movie using the same (or is it exactly the same?) codec. Audio stream is direct stream copy!
How can I progress now??
Apart from changing the bitrate, how do the DivX compressor options affect 'data stream type???
Cheers Boys & Girls |
| Morsa |
| Posted: Dec 7 2002, 06:50 PM |
Be more clear please. |
