Sound Can't Syn, audio don't syn with video
dale_chua
Posted: Nov 11 2002, 04:57 PM
hi guys,
When i try to load to split some Divx (avi) files, there is a message that says.....
VBR audio stream detected
"Virtualdub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 41897 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder (bitrate 150.4 +/- 15.1kbps)"
Does anyone encounter this error b4 and know how to solve this problem.
Thanks in advance....
Morsa
Posted: Nov 11 2002, 05:49 PM
This messagge appears always that you try opening a Variable BitRate audio stream.
If you wanna go the Vdub way you´ll have to do what the messagge says.
BaronVlad
Posted: Nov 15 2002, 07:15 PM
Terrorhörnchen
NanDub should solve that problem
Hochachtungsvoll
BaronVlad
2 replies since Nov 11 2002, 04:57 PM Track this topic | Email this topic | Print this topic
