| uhhuhhim |
| Posted: Feb 6 2011, 08:26 PM |
Hey everyone,
I'm not sure if this is the appropriate forum for this questions, so mods please feel free to move it, but:
I'm fairly new to AVISynth and what it does. I mostly use it to open non-AVI files for editing like most people would, but I've encountered the following error twice and want to what the general solution is:
"AviSynth open failure: AviSynth error: YV12 images for output must have a width divisible by 4 (use crop)!"
What needs to be added to the code [DirectShowSource("nameoffile.mp4")] to resolve the error above if it's encountered? |
| ale5000 |
| Posted: Feb 6 2011, 08:30 PM |
If you use Avisynth just to open non-AVI files then you could try to switch to input plugins: http://forums.virtualdub.org/index.php?act...=ST&f=7&t=12664 It is easier and you could also use Direct Stream Copy in this way.
I suggest the Quicktime input plugin for .mp4 files.
| uhhuhhim |
| Posted: Feb 6 2011, 08:37 PM |
Well, I really don't know much about plugins in general, but I was just wondering what the error itself meant?
The original file had dimensions of 718x364. I don't understand the error, what would the dimension need to be changed to in order for the error to disappear?
Edit: I also checked out the plugins list you linked and clicked on Quicktime (http://www.tateu.net/software/). Which program would I click on in the list, the one for AVISynth or VirtualDub? |
| Posted: Feb 6 2011, 08:56 PM |
1)
| QUOTE | | The original file had dimensions of 718x364. I don't understand the error, what would the dimension need to be changed to in order for the error to disappear? |
It's self explanatory
The message says images can only be outputted at sizes that are multiples of 4 Your size is 718x364
718/4 = 179.5 This is obviously not divisible by 4, so it shows a message telling you that
You want to crop it to 179*4 = 716
The command in avisynth for that is Crop(0,0,716,364)
2)
| QUOTE | | Edit: I also checked out the plugins list you linked and clicked on Quicktime (http://www.tateu.net/software/). Which program would I click on in the list, the one for AVISynth or VirtualDub? |
If you want avisynth to be able to decode quicktime, then you'd pick the quicktime one If you want virtualdub to be able to decode quicktime, then you'd pick the virtualdub one
| uhhuhhim |
| Posted: Feb 6 2011, 09:21 PM |
| QUOTE (dloneranger @ Feb 6 2011, 08:56 PM) | You want to crop it to 179*4 = 716
The command in avisynth for that is Crop(0,0,716,364) |
I would enter that as line 2 of the script file, right?
| QUOTE | | If you want virtualdub to be able to decode virtualdub , then you'd pick the virtualdub one |
That's what I thought, but: What is the difference between the install zip and the source zip? I don't get it. |
| Posted: Feb 6 2011, 09:40 PM |
| QUOTE | | I would enter that as line 2 of the script file, right? |
Yes
| QUOTE | | That's what I thought, but: What is the difference between the install zip and the source zip? I don't get it. |
The install is the program or plugin etc Source code is the code the author wrote that a compiler turns into the finished files
You only ever download the sourcecode if you want to compile it It's one of those "if you dont' know what it is, you don't want it" things
| uhhuhhim |
| Posted: Feb 6 2011, 10:40 PM |
| QUOTE (dloneranger @ Feb 6 2011, 09:40 PM) | | Yes |
Ok.
| QUOTE | The install is the program or plugin etc Source code is the code the author wrote that a compiler turns into the finished files
You only ever download the sourcecode if you want to compile it It's one of those "if you dont' know what it is, you don't want it" things |
Ok. Thanks for being so patient with my questions. I'm gonna try the crop command in my .avs file and if that doesn't work, I'll try downloading and installing the plugin. I'll come back here if I have a problem
Edit: The Crop(0,0,716,364) command worked perfectly, dloneranger. I just have a small question: What do the zeroes in the command represent? |
| ale5000 |
| Posted: Feb 6 2011, 11:19 PM |
The video have four sides, four values to crop from four sides
| Gral |
| Posted: Feb 7 2011, 12:08 AM |
You can use ConvertToRGB() instead - if you don't want crop. |
