Extracting Image Sequence 1 Image Every Second
jaffy1229
Posted: Jan 31 2011, 10:37 PM
I have a lots of video files that i need to scan through to find particular sequences. I would like to do this by extracting a frame every second and viewing the images in image viewer.
I can't seem to do this in virtual dub using the pull down menus as it extracts every single frame. Can a script do this job? I am unfamilar with scripts so if it is possible, any further help is appreciated.
Thanks
ale5000
Posted: Jan 31 2011, 10:50 PM
First set Video => Frame Rate => Frame rate conversion => Convert to fps => 1
Then use File => Export => Image sequence
New VirtualDub forum
jaffy1229
Posted: Jan 31 2011, 11:01 PM
Thanks for the help, I would never had figured that out!
Cheers!
2 replies since Jan 31 2011, 10:37 PM Track this topic | Email this topic | Print this topic
