| angela18 |
| Posted: Dec 15 2010, 06:44 AM |
Hi, is it possible to use VirtualDub or any filter to convert a movie to a Piece Wise Linear format. This is just a voltage as a function of time signal. I can translate a sound WAV file to PWL using Matlab, but I never heard anything about converting video to PCWL. Is it possible? Thank you so much. Angela. |
| fredgiblet |
| Posted: Dec 16 2010, 03:16 AM |
VDub can only output to .avi, if the file type in question doesn't work in an .avi file then the answer is no. |
| Loadus |
| Posted: Dec 16 2010, 04:56 AM |
It is possible to write an output plugin for it, the plugin SDK is available.
| angela18 |
| Posted: Dec 16 2010, 01:26 PM |
Ok Thanks for the answers. IŽll check the SDK and IŽll try it out to write a plug in to output a signal file. Thanks, |
| fredgiblet |
| Posted: Dec 17 2010, 03:17 AM |
| QUOTE (Loadus @ Dec 16 2010, 04:56 AM) | | It is possible to write an output plugin for it, the plugin SDK is available. | He's released an output plugin SDK? I thought that was input only. |
| Loadus |
| Posted: Dec 19 2010, 04:15 PM |
| QUOTE (fredgiblet @ Dec 16 2010, 09:17 PM) | | QUOTE (Loadus @ Dec 16 2010, 04:56 AM) | | It is possible to write an output plugin for it, the plugin SDK is available. |
He's released an output plugin SDK? I thought that was input only. | Not sure, but I thought the output stuff is also available - if not publicly, I would hope it's available at least on request.
| Posted: Dec 19 2010, 10:53 PM |
There is no output plugin support at this time, but the external encoder support in the experimental branch allows you to write one relatively easily, if YV12 input is OK. |
| Loadus |
| Posted: Dec 20 2010, 04:29 AM |
| QUOTE (phaeron @ Dec 19 2010, 04:53 PM) | | ... the external encoder support in the experimental branch ... | This is what I meant - meine bÀd énglish had me talking about a "plugin". Sorry. Hehe. ^^
