| omya |
| Posted: Dec 1 2010, 03:42 AM |
so i downloaded a old movie called Makenna's Gold but it isnt working in my samsung lcd tv (it does support all formats even the 3gp n flv but doesnt support dis audio format vdo is getting displayed fine but audio isnt working ) so i searched gooogle for help den i got to know abt dis software i installed it also tried converting it but wot now hapening is vdo's size is increasing to 50gb lol so wot i want to do is keep the vdo setings defalut (i mean same as they r in the vdo) n change the audio to mp3 can anyone help on dis ??
btw dese r the default vdo n audio codecs in the movie (all i want to do is change the audio to mp3 so it will work in my lcd tv) http://i51.tinypic.com/9zm71k.jpg
thax in advance |
| fredgiblet |
| Posted: Dec 2 2010, 01:01 AM |
First off, spelling, it takes like 10 seconds longer to spell out words and this isn't SMS, you don't have a 144 character limit.
Second off, go to the Video menu in the bar at the top and select Direct Stream Copy. |
