| samuelps2 |
| Posted: Nov 1 2010, 02:13 AM |
Does the current version of VirtualDub supports coverting a sequence of image to avi in command line? If so, How does it work? If not, could you suggest a way to do the same think once I want to invoke it and automatically generate avi files with the image sequence in a specified directory when I press a button in my programed UI? Thanks for help!! |
| Posted: Nov 3 2010, 09:32 PM |
There is currently no way to do this from a directory. You can do it from a series of sequentially numbered files (image0001, image0002, etc.) if you open the first image. |
| chchatham |
| Posted: Jan 5 2011, 09:16 PM |
I have the same problem - have had trouble understanding what is supported via command line and what is not. If anyone could provide a hint in the right direction that would be helpful.
Currently I have:
C:\Users\Chris\Documents\VirtualDub-1.9.11\vdub.exe /capture /max /capfileinc heatmapmovieBYRESP1NoDistList0.png
but it doesn't seem to work... |
| Posted: Jan 5 2011, 09:25 PM |
| QUOTE (chchatham @ Jan 5 2011, 10:16 PM) | Currently I have:
but it doesn't seem to work... | Yep, it makes no sense
/capture and its related options are for recording from eg a webcam
Are you trying to load a series of png's, or capture from a camera to a series of png's ?
| chchatham |
| Posted: Jan 6 2011, 01:03 AM |
Yep - I am calling virtualdub from within R. I am just trying to make an avi file from a sequence of images (heatmapmovieBYRESP1NoDistList0.png, heatmapmovieBYRESP1NoDistList1.png, heatmapmovieBYRESP1NoDistList2.png, etc). I need to do it from the command line because I have a few hundred different movies to create.
Thank you so much for any help. |
| chchatham |
| Posted: Jan 6 2011, 01:22 AM |
Well it looks as though this person needed to do something very similar:
http://forums.virtualdub.org/index.php?act...nd,command+line
I have now gotten it to work following those instructions and using the following command:
C:\\Users\\Chris\\Documents\\VirtualDub-1.9.11\\vdub.exe /i compress.vcf heatmapmovie0.png heatmapmovie.avi
Thanks all! Hopefully this post will help others find the solution.
| Posted: Jan 6 2011, 01:57 AM |
First you'll need to make a script to use Easiest way to do that is to start virtualdub, and go through the motions of what you want to do eg set full processing for video, pick a compressor and it's settings, set no audio, load the first .png file of a set Then in the file menu, go to 'Save processing settings' and save it as c:\MyScript.vcf Quit virtualdub
Open the MyScript.vcf file in notepad, and you'll see something like this - (not identical though)
| CODE | VirtualDub.audio.SetSource(0); VirtualDub.audio.SetMode(1); VirtualDub.audio.SetInterleave(1,500,1,0,0); VirtualDub.audio.SetClipMode(1,1); VirtualDub.audio.SetConversion(0,0,0,0,0); VirtualDub.audio.SetVolume(); VirtualDub.audio.SetCompression(); VirtualDub.audio.EnableFilterGraph(0); VirtualDub.video.SetInputFormat(0); VirtualDub.video.SetOutputFormat(0); VirtualDub.video.SetMode(3); VirtualDub.video.SetSmartRendering(0); VirtualDub.video.SetPreserveEmptyFrames(1); VirtualDub.video.SetFrameRate2(0,0,1); VirtualDub.video.SetIVTC(0, 0, 0, 0); VirtualDub.video.SetCompression(0x64697678,0,10000,0); VirtualDub.video.SetCompData(3532,"somestuffhere"); VirtualDub.video.filters.Clear(); VirtualDub.audio.filters.Clear();
Now, you need to add 2 lines to this
First, at the top add VirtualDub.Open( VirtualDub.params[0] ,"",0); Then at the bottom, add VirtualDub.SaveAVI(VirtualDub.params[1]);
Save that, and quit notepad
---------------------------------------------- Now we make a .bat file to run the script (change all file paths shown here, to what's on your pc)
The .bat file could read like this
| CODE | "c:\virtualdub\VDub.exe" /i "c:\MyScript.vcf" "%~1" "%~1.avi" /x if %errorlevel% == 0 goto ok :err echo Error %errorlevel% with %~nx1 goto theend :ok echo Ok, done :theend pause |
Now, if you drop the first .pgn file onto the batch file, it'll join up all the sequentially numbered .png's and save them to the same location with that file's name+'.avi'
So if you saved the .bat as eg c:\myscript.bat then myscript.bat "c:\pics\img0001.png" would save an avi to the same location
If you wanted all the avi's to go to a different folder you could use "c:\virtualdub\VDub.exe" /i "c:\MyScript.vcf" "%~1" "c:\FinishedVideos\%~n1.avi" /x in the bat file instead
| brontosaurusrex |
| Posted: Jan 13 2011, 08:05 AM |
i just wonder, if say one has 5 image sequences in one folder, how non-trivial would be the code to detect sequences and show only 5 clips for the user to select? |
| Posted: Jan 13 2011, 10:13 AM |
Quick answer Harder than just splitting the 5 sequences into subfolders
Longer answer
Its a question of 'how useful would that be' There's a long list of suggestions the author already has He's also got his own list of thing he wants to do Now, you have to put those things into some kind of order
A fairly decent order is What's most important What do I actually want to do What do I have time for
Now, if it was my list of things to do, right down at the bottom would be 'Things people want me to do, that they can do by themselves in 10 seconds' Underneath that would be 'Things 1 or 2 people want me to do, that they can do by themselves in 10 seconds'
That may sound harsh but it's just a practicality Even the best idea in the world will be thrown away it only one person would use it
To get features added, the best way is to interest the programmer in doing them
Think about the things you'll do for other people when asked If it's fun, something you like doing, or a challenge, then you'll probably do it If it boring, time consuming, and they can do it themselves, well....... insert favourite excuse and run away
On the other hand there's always the 'I'm bored' moments, when the author picks an interesting or simple suggestion off the list at random, just for something to do
