Error?
atr232000
  Posted: Feb 13 2003, 07:09 PM
Hi there you lot
i am trying to put 2 cd videos on to 1 cd to save space i decompress the audio and save as .wav
then add avi then avi segment
then load the audio in and set up the full prossessing mode to 128 kbps CBR lame mp3
then sett up the video full prossessing mode sett compression to Xvid codec and the KBPS the Caculator says
then save as avi
25% of the way though i gett this
i get this on vertualdub and nandub can anyone help me please
Kippesoep
Posted: Feb 13 2003, 09:11 PM
There is a corruption in one of the frames of your source files. Try using "Scan video stream for errors" from the Video menu. I've never had to use it myself, but I gather it gives you a list of frames that cannot be decoded properly and masks them so they are no longer processed. Then, you should be able to save your AVI properly.
atr232000
  Posted: Feb 13 2003, 10:36 PM
Well thanks for your advice but it picked up the bad frames but them i started to rencode it it still had the same error
Kippesoep
Posted: Feb 14 2003, 06:30 AM
Try manually masking the bad frames. Use the "Go to" function in the edit menu and enter the number of the bad frame. Then, choose "Mask selected frames" from the edit menu. Repeat for each bad frame.
atr232000
Posted: Feb 14 2003, 11:03 AM
Kippesoep
Posted: Feb 14 2003, 05:05 PM
Doesn't the scanning process give you a list of frame numbers? If not, check where your encode failed the last time.
reman
Posted: Feb 22 2003, 08:11 PM
QUOTE (Kippesoep @ Feb 14 2003, 12:05 PM)
No, it does not. In fact, I have never seen any version do that. I would be very helpful smile.gif
6 replies since Feb 13 2003, 07:09 PM Track this topic | Email this topic | Print this topic
