| rjisinspired |
| Posted: Aug 27 2010, 11:14 PM |
This will be the first time ever using virtualdub's batch processor.
Since I can't load a lot of AVC/mpeg4 videos I thought to resave them to huffyuv for working on but I am getting the feeling that the batch processor doesn't accept MP4 directly for saving out to huffyuv.
I just tried Any Video Converter instead of Vdub to process 72 clips to huffyuv and got rapid fail on each file attempt. The dinging sound kind of drove me a little crazy, lol.
I don't know if it is me or my programs. I know Vdub can import my mp4 files but I'm not sure it can through the batch processor? |
| Posted: Aug 27 2010, 11:24 PM |
Just tried, and both methods of adding large batches work with mp4's here That's 1)the batch wizard 2)the job control dialog. menu->edit->process directory
| rjisinspired |
| Posted: Aug 27 2010, 11:35 PM |
Getting errors on each file here. I'll stick to Vegas right now since I'm in it. Have to get this job done. |
| Posted: Aug 27 2010, 11:49 PM |
Maybe this will work http://rapidshare.com/files/415548570/VDub...ersion.zip.html
It's a modified version of virtualdub that I use It works a bit differently with mp4, mov and directshow files (wmv, asf etc)
| rjisinspired |
| Posted: Aug 27 2010, 11:57 PM |
I'm afraid your version didn't work for me. The files just error out really fast.
In your version I saw in the list, the destination of the file ended with .avi. In the Vdub version they were .mp4. |
| Posted: Aug 28 2010, 12:04 AM |
dang!!
there's something abut your system and mp4's..........
do you have graphedit? if you do could you post a screenshot of what happens if you drop a file into it
re: avi extension one of the thing mine does is to change the save file extension to avi in the batch processes saves renaming them later on
| rjisinspired |
| Posted: Aug 28 2010, 12:09 AM |
| Posted: Aug 28 2010, 12:13 AM |
pdt ipp????? all i can find out about that is that people have problems with it
try lowering it's merit with gspot or radlight filter manager to 'do not use' or 'unlikely' mine shows ffdshow video and audio, and they work fine
| rjisinspired |
| Posted: Aug 28 2010, 12:20 AM |
I go to use radlight and when selecting "do not use" the rest of the codecs including Xvid shows as "do not use" I'm lost. |
| Posted: Aug 28 2010, 12:23 AM |
You pick the filter you want to adjust in the list change the merit drop down click the set merit value button
(the drop down doesn't change automatically to show what each filters metit is - it's a bit crappy)
| rjisinspired |
Looks likes files from the Flipshare application. They use intel? files. |
| rjisinspired |
| Posted: Aug 28 2010, 12:26 AM |
What's another directshow filter changer? This one doesn't appear to work. |
| Posted: Aug 28 2010, 12:27 AM |
Yeah, those are the ones I hate 'our own special filters' and judging by all the 'trouble' posts on google, I guess other people hate them as well ;-)
I'm trying to send you an email at the moment.... but we're on bandwidth cap here till about 3am meanwhile you might want to look at http://corecodec.com/products/coreavc
| rjisinspired |
| Posted: Aug 28 2010, 12:29 AM |
I disabled those filters with Nir Sofers program and now graphedit won't won't load the files. Hey at least I got them disabled :-D |
| Posted: Aug 28 2010, 12:31 AM |
Check your ffdshow vwf configuration and make sure all the h264 etc you need are turned on
