| rjisinspired |
| Posted: Aug 23 2010, 10:29 PM |
I am working on smart rendering a file but I'm realizing the extensions are different and I know Vdub can't save back to MP4 directly.
I believe I would have to demux the MP4 and put it into an AVI container then mux it back into an MP4 container after I'm done but then how would I use smart rendering for the following AVI intermediate file?
Spec of the MP4 file in question: --------------------------------------------------------------------------------------------------------- General Complete name : C:\Documents and Settings\rjisinspired\Desktop\Flip-0819-232010\VID00162.MP4 Format : MPEG-4 Format profile : Sony PSP Codec ID : MSNV File size : 50.4 MiB Duration : 46s 400ms Overall bit rate : 9 116 Kbps Encoded date : UTC 2010-08-23 13:23:31 Tagged date : UTC 2010-08-23 13:23:31
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 46s 400ms Bit rate mode : Variable Bit rate : 8 980 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.325 Stream size : 49.7 MiB (99%) Language : Japanese Encoded date : UTC 2010-08-23 13:23:31 Tagged date : UTC 2010-08-23 13:23:31
Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 46s 393ms Bit rate mode : Constant Bit rate : 132.3 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Stream size : 742 KiB (1%) Language : Japanese Encoded date : UTC 2010-08-23 13:23:31 Tagged date : UTC 2010-08-23 13:23:31 -----------------------------------------------------------------------------------------------------
Would x264 or FFDshow work on the intermediate AVI file? |
| rjisinspired |
| Posted: Aug 23 2010, 10:45 PM |
I'm finding this to be too much hassle for all that it is worth.
I used Yamb to demux then AVCtoAVI to create a video-only file in AVI container, then I had to resave the AAC file to Wav, import that all into Vdub and then..... Yeah. Think I'll just stick to using some other intermediate. |
