Colorbars In Avisynth Not Working Out
rjisinspired
Posted: Jul 3 2010, 12:45 AM
I did at one time get colorbars to work but I may not have it correct?
Colorbars(704, 480, "RGB32")
Tone(length=10.0, frequency=440, samplerate=48000, channels=2, type="sine")
Says colorbars doesn't have a video stream. I then added this line:
Blankclip(300, 704, 480, "RGB32", 30, 1001, 48000, true, true)
Still doesn't work. According to the avisynth wiki all that is needed is the colorbar line.
rjisinspired
Posted: Jul 3 2010, 12:57 AM
huh? I removed the "tone" line and now get bars? Why can't tone work with colorbars? I don't like the tone that is default. Looks like I'll have to go into audition and replace it, sigh.
Posted: Jul 3 2010, 02:34 AM
avisynth returns the last clip used
the way your doing it, the last clip was audio only
you need to mix the two together
a=Colorbars(704, 480, "RGB32")
b=Tone(length=10.0, frequency=440, samplerate=48000, channels=2, type="sine")
audiodub( a, b )
rjisinspired
Posted: Jul 3 2010, 03:08 AM
Thanks.
I was scratching my head there for a while.
3 replies since Jul 3 2010, 12:45 AM Track this topic | Email this topic | Print this topic
