| fafa |
| Posted: Jun 9 2010, 03:01 PM |
Hi all, I am using Virtualdub scripting and I need to apply a Inverse Telecine with 1.9.1 release .
But the interpolate fiter config is not documented in http://www.virtualdub.org/docs/vdscript.txt
Here is some code: | QUOTE |
declare myfilter; myfilter=VirtualDub.video.filters; myfilter..Add("interpolate"); myfilter.instance[0].Config(a,b,c) ;
I understand that Config have 3 parameters ...
Thanks all
PS: using setFrameRate crash |
| rjisinspired |
| Posted: Jun 9 2010, 09:45 PM |
I don't have an answer for you for this topic but I noticed that there are two dots in the "myfilter.add" part of your code. Is that a syntax error or is there suppose to be a double dot there? |
| fafa |
| Posted: Jun 10 2010, 07:39 AM |
A little mistake in the message.
And still no idea of the needed config parameters of "interpolate" filter (which was old Inverse Telecine feature of changing frame rate.
Any idea ? |
| stephanV |
| Posted: Jun 10 2010, 08:05 AM |
You don't have to use the interpolate filter for IVTC; it is not its replacement. The IVTC filter is.
If you are not sure how to configure a certain filter ina script an easy way to figure this out is to create the an instance of the filter within VirtualDub, configure it, and then save a processing settings file, which you can view in a text editor.
| fafa |
| Posted: Jun 10 2010, 01:53 PM |
| QUOTE (stephanV @ Jun 10 2010, 08:05 AM) | You don't have to use the interpolate filter for IVTC; it is not its replacement. The IVTC filter is.
If you are not sure how to configure a certain filter ina script an easy way to figure this out is to create the an instance of the filter within VirtualDub, configure it, and then save a processing settings file, which you can view in a text editor. |
Great ! wonderful feature I didn't known . But when I execute it in a script frame number are inchanged instead of decreasing to a 25fps .
I am trying to changing fps in a script, from 60p to 25p.
I test it using filter menu. No problems but when I am running the saved process in a script => same frames number... So the last frame is repeted during most of the end of the stream.
here is my script:
| CODE | //$ 1920*1080p60 => 640*480p25
//$ video VirtualDub.Open(VirtualDub.params[0]); //$ Audio VirtualDub.audio.SetSource(VirtualDub.params[1],"");
//------------------------------ End of gen code VirtualDub.audio.SetMode(0); VirtualDub.audio.SetInterleave(1,500,1,0,0); VirtualDub.audio.SetClipMode(1,1); VirtualDub.audio.SetConversion(0,0,0,0,0); VirtualDub.audio.SetVolume(); VirtualDub.audio.SetCompression(); VirtualDub.audio.EnableFilterGraph(0); VirtualDub.video.SetInputFormat(0); VirtualDub.video.SetOutputFormat(7); VirtualDub.video.SetMode(3); VirtualDub.video.SetSmartRendering(0); VirtualDub.video.SetPreserveEmptyFrames(0); VirtualDub.video.SetFrameRate2(0,0,1); VirtualDub.video.SetIVTC(0, 0, 0, 0); VirtualDub.video.SetCompression(); VirtualDub.video.filters.Clear(); VirtualDub.video.filters.Add("interpolate"); VirtualDub.video.filters.instance[0].Config(0, 25, 0); VirtualDub.video.filters.Add("resize"); VirtualDub.video.filters.instance[1].Config(640,360,0,4,3,1,640,480,4,3,1,7,1,0x000000); VirtualDub.audio.filters.Clear();
//------------------------------ End of gen code //$ Save
VirtualDub.SaveAVI(VirtualDub.params[0]+"_vga25.avi"); VirtualDub.audio.filters.Clear();
How to adapt new frame number (video duration in fact ) when decrasing from 60 fps to 25 fps |
| stephanV |
| Posted: Jun 10 2010, 02:38 PM |
I didn't mean to say that you should copy the whole processing files settings file. Only that you can figure out how the filter should be configured that way...
| fafa |
| Posted: Jun 10 2010, 03:47 PM |
| QUOTE (stephanV @ Jun 10 2010, 02:38 PM) | | I didn't mean to say that you should copy the whole processing files settings file. Only that you can figure out how the filter should be configured that way... | That's right. The point is now that the filter have 2 different behavior, One correct using interface, one not correct in scripting. This is why I copied the most part of the generated script.
My probleme is maybe an interaction - implicit or not - with one of these routines. Frame number may change (I reduce fps) but not.
sorry |
| Posted: Jun 11 2010, 05:01 AM |
You need to reset/recreate the subset if you have added or removed filters like interpolate that change frame rate. The reason is that the subset (timeline) is created in post-filter frame numbers, so if you don't redo it, the length is wrong. The UI automatically does this when you exit the filter dialog, but this doesn't happen for scripts. |
| fafa |
| Posted: Jun 11 2010, 09:54 AM |
| QUOTE (phaeron @ Jun 11 2010, 05:01 AM) | | You need to reset/recreate the subset if you have added or removed filters like interpolate that change frame rate. The reason is that the subset (timeline) is created in post-filter frame numbers, so if you don't redo it, the length is wrong. The UI automatically does this when you exit the filter dialog, but this doesn't happen for scripts. |
Woks fine !!! I do a "VirtualDub.Subset.Delete();" after interpolate filter and got the correct frame number and A/V sync.
Thanks a lot |
