Save My Actions In Vdub, Saving operations performed
rechmbrs
  Posted: Jun 4 2010, 07:12 PM
It seems that I am in an iterative loop on a couple of projects. Most of what I'm doing is importing MPEG files and removing portions and then outputting AVI for the person to peruse. Problem is that they keep changing the parts they wish.
Is there a way other the writing down where I rejected or copied the original file in making the AVI? I save all of the other parameters in a Processing settings file.
I appreciate any help.
Thanks,
stephanV
Posted: Jun 4 2010, 08:34 PM
I'm not completely sure about your question but if you use File > Save Processing Settings, in that dialog box you can see a checkbox in the lower left corner that allows you to also save your edits.
useful links:
rechmbrs
  Posted: Jun 4 2010, 08:42 PM
I'll try what you mentioned. Looks like it will work.
Thanks a bunch. VDub is a very good program.
2 replies since Jun 4 2010, 07:12 PM Track this topic | Email this topic | Print this topic
