| Fess |
| Posted: Jan 14 2003, 01:01 AM |
Hello,
I wanted to cut clips from 2 seperate huge Avi's. I did the cut and saved at 'direct stream copy' video/audio for both clips. Then I tried to append them and got this error:
'Cannot append segment: The video streams have different sampling rates.
'file info' on the first avi was 9.997fps(100034 us)
'file info' on the second avi was 9.996fps(100045 us)
I re-cut the first clip at 'direct stream copy' and changed the framerate 9.996fps.
I still cannot append the clips. The 'file info' on the re-cut clip is now9.996fps(100040 us)
Is the (100040us) and (100045us) difference the reason I cannot append? How do I make them the same?
How do I make the first clip (100045us)? Because if the fist clip is 9.996fps(100040us) and the second clip is 9.996fps(100045 us) is won't append. |
| ChristianHJW |
| Posted: Jan 14 2003, 10:27 AM |
Read the 'sticky' posts in the Newbie section, and please try to avoid double posting in future ...
| Fess |
| Posted: Jan 14 2003, 04:26 PM |
Hello,
Yes, sorry about the mutli posts. jcsston have provide me with the solution. He stated:
"Direct Stream Copy both your avi files setting the frame to 9.996 for each one."
It worked!
Thanks again Fess |
