| cocksy_boy |
Posted: Jan 12 2003, 11:31 PM |
(Sorry if this should be in the noobie section - wasn't sure!)
Hi All
Basically, I'm having a problem joining (using the append option in virtualdub) 2 AVI's together. They are both exactly the same in terms of frame rate, audio, size, codec, etc, and they do join together,
BUT
In the second half of the joined file, the audio is out of synch with the video . The first half is fine, and on the two separate files the audio is fine in both sections.
I have been using the 'direct stream copy' for both audio and video, as thats what i want, a nice quick way to join a bunch of avi clips.
Any help would be much appreciated, as im a bit confused , thanks in advance, laters
Cocksy |
| Neo Neko |
| Posted: Jan 13 2003, 05:04 AM |
VirtualdubMod Alpha tester
What's the video source. DVD? Perhaps you need to account for a delay. |
| Posted: Jan 13 2003, 06:13 AM |
See if this thread helps: Audio Sync Not Fixed In 1.4.13
| cocksy_boy |
| Posted: Jan 13 2003, 11:59 AM |
Thanks fcchandler, that other thread is the exact problem i'm having!
Neo Neko - I think the original source may have been DVD, but I only have the separate avi files, and each of them on their own is just fine, completely in synch audio all the way through, it just gets screwed up when i try to join the separate parts!
I'm gonna give avisynth a go, but never used it before, and seems quite daunting! Thanks
Cocksy |
