Compress Tv Eps, Compress TV Eps
AngryChef
Posted: Jan 9 2003, 03:59 AM
Here is My problem: I encode to Divx and the video stalls while the sound continues then the picture just skips to another section and the same thing happens over and over.
Here is What I do:
I capture some television eps at
720x480
Mpeg1
7.22kbps
44,100 16 Bit Stereo
It makes a file anywhere from 1.4 to 1.6 gb
And The files plays Great! but there are comercials and the size is huge
I then open VDUB and open the file choose full proccesing for both audio and video. For Audio i choose MPEG layer 3, 128k, 44,100.
and for video I choose Divx 5.0.2. I then Setup a 1rst then 2nd pass for the encode. job control and 2 hours later i have the crappy file.
I have experimented with divx and changed the kbps to
1500kbps with a keyframe of 1200 and motion estimate 50%=no luck
932kbps with a keyframe of 300 and motion estimate 100%=no luck
Please any suggestions on what to do would be great!!
AngryChef
Posted: Jan 9 2003, 04:01 AM
wanted to add.
i edit the comercials out on same encode.
Posted: Jan 9 2003, 04:42 AM
Sounds like your computer is choking (not fast enough to decode DivX at that resolution and/or bitrate). There are a number of possible solutions:
- In the Decoder Configuration for DivX, set "Quality Level" to MIN
- or, try a lower resolution like 512 x 384 or 448 x 336
- or, get a faster computer.
(I've also heard that ffdshow may help with this problem, but I don't use it myself so I can't say for sure.)
AngryChef
Posted: Jan 9 2003, 04:56 AM
thanks for the reply.
I found that if I play it in divx player rather than Windows media player, which i use to play all my divx files, it works much better. hmm. a faster pc would be able to play in wmp better? or am i missing somthing for wmp?
jcsston
Posted: Jan 9 2003, 05:12 AM
Matroska Dev
ffdshow has helped me play higher res content. I would recommend you try it out.
I have a system that acts similar to that. K-6 300mhz 320x240 15fps using DivX player plays but in WMP chop chop. An even stranger thing is that my M2 250mhz can play 320x240 30fps smoothly with WMP 6.4
Use the Matroska file format
AngryChef
Posted: Jan 9 2003, 05:20 AM
thanks again. next test capturing in vdub mmc is ok but everyone says vdub is better off for comparison
AngryChef
Posted: Jan 9 2003, 05:24 AM
oh yeah fdshow doesnt install, i found dsp2show on their site downloaded and installed that but ffdshow gives me "error opening file for writing c:\windows\system32.ffdshow.ax" then tells me to click abort?hmm
AngryChef
Posted: Jan 9 2003, 05:31 AM
WOW!!! all i did was download it again and it installed fine this time. the vids play great in the wmp, thanx for all your help i know most of this had nothing to do with vdub smile.gif
7 replies since Jan 9 2003, 03:59 AM Track this topic | Email this topic | Print this topic
