Make Two Into One
butterfly
Posted: Jan 6 2003, 05:02 PM
hi all
im trying to make a clip out of some homemade movies but when i try to put two of them together with "append avi segment" on the "file" menu it says that the video streams have different deta formats.
do you know what can i do to make it work?
i mean, isnt it the idia of virtualdub? to make things like this?
thanks again
Posted: Jan 6 2003, 08:25 PM
VirtualDub can't join AVIs unless they have exactly the same format, but you may be able to make it work with an Avisynth script:
part1 = AVISource("part1.avi").ConvertToRGB
part2 = AVISource("part2.avi").ConvertToRGB
AlignedSplice(part1, part2)
butterfly
Posted: Jan 6 2003, 11:02 PM
thanks i'll try it,
but it is wired, i thought that virtualdub sepoes to do idsacly this but ok...
thanks again
2 replies since Jan 6 2003, 05:02 PM Track this topic | Email this topic | Print this topic
