Home Video Quality Issues, How to improve quality
sea4me
  Posted: Jan 4 2003, 01:53 AM
Have tried a few times to produce an SVDC with good quality.
None of my attempts so far can be descibed as very successful.
Problem is that the s-vcd is sort of blocky specially when there is a lot of movement.
There doesnt seem to be any interlacing problems and everything else looks normal. I remember having read somewhere that home tapes are difficult to get good quality because its hard to keep the camera still when capturing.
The original source is an analogue tape. Converted with TMPGEnc with max constant bitrate and at best(slowest) conversion.
So the questions are as follows :
Is this caused by insufficient datarate when converting from avi to mpeg?
If so, will the result be better if i make an ordinary vcd?
Is there a way around it?
I have a pioneer DVD 343 player which may be able to cope with higher bitrates. Is it adviceable to try it?
Please help
ChristianHJW
Posted: Jan 4 2003, 08:58 PM
Stop converting your AVIs to VCDs/SVCDs and buy a MPEG4 capable standalone instead, like the
KiSS DP 450
or the
Neuston DVX 1201
wink.gif wink.gif ....
sea4me
Posted: Jan 5 2003, 12:58 AM
That sounds a bit drastic.
Would u care to broaden my horizon.
Sounds like your conclusion is that vcd/svcd is just to forget for home video purpose.
What about my ?? Am I way off ?
Neverheard about MPEG-4 standalone. Would my problems vanish if I get a DVD burner?
Posted: Jan 5 2003, 04:47 AM
QUOTE (sea4me @ Jan 3 2003, 09:53 PM)
Have tried a few times to produce an SVDC with good quality.  None of my attempts so far can be descibed as very successful.
Same here. IMHO, SVCD is not a good choice for VHS source.
Yes, and unavoidable VHS noise. But VirtualDub's own "temporal smoother" filter can perform wonders at settings around 3-4.
I believe so, but it's all relative. VCD has "worse" resolution at 352 x 240, but the bits-per-pixel ratio is about 24% higher, so you should get "better" reproduction and less blocks.
Is there a way around it?  I have a pioneer DVD 343 player which may be able to cope with higher bitrates. Is it adviceable to try it?
I doubt that it would work, as the maximum bitrates for VCD and SVCD are pretty much set in stone. But if you do try it, use a CD-RW and you won't lose anything if it doesn't work.
sea4me
Posted: Jan 5 2003, 10:03 AM
Thx for taking the time to enlighten a rookie.
Just another question.
Will a DVD burner improve the quality a bit a lot or?
Posted: Jan 5 2003, 04:19 PM
QUOTE (sea4me @ Jan 5 2003, 06:03 AM)
If you are talking about creating true DVD content (VOBs and all), then yes, the quality will be much better.
5 replies since Jan 4 2003, 01:53 AM Track this topic | Email this topic | Print this topic
