| junglemike |
| Posted: Dec 26 2002, 01:34 AM |
If i understand correctly, when you split file in some point, Dub goes to the nearest keyframe instead(as i tried it cannot split between kframes- ) But the question is - Is The audio(if exist) it taken from the point of splitting or from the nearest keyframe. i.e if i have some bad file that heve very few keyframes - could be some a/v synch problem with splitting. Thankx for any welcome replies. |
| jcsston |
| Posted: Dec 26 2002, 10:46 PM |
Matroska Dev
In my experience not cutting on keyframes has not cause audio sync problems. About not cutting on keyframes AviUtil let me cut on non-keyframes but the resulting file was marred with floating blocks
