Pb With The Sound
podge
Posted: Dec 16 2002, 07:10 PM
hi, i have a problem with the sound when i use VD to make a divx, pictures are not played in the same time than sounds. i need help
thanks !
Anime_Fan
Posted: Dec 16 2002, 07:44 PM
I don't know if you just have a delay or if the sound gradually gets worse...
I assume you have CBR audio...
Audio delay: Audio->Interleaving -> Audio Skew Correction: Enter value... Negative ones allowed IIRC...
Video is played in a tempo different from audio:
Video-> Frame Rate (Change so video and audio durations match...)
Hope this helps you...
1 replies since Dec 16 2002, 07:10 PM Track this topic | Email this topic | Print this topic
