| Tongari |
| Posted: Apr 7 2004, 05:55 PM |
I need to Combine multiple sets of image files i captured from video. is it possible?.............because these images are taking alot of space on my pc. |
| stephanV |
| Posted: Apr 7 2004, 06:27 PM |
you can join avis with file--->append segment avi
appending will only work when: - frame size of the videos is the same - frame rate is the same - video format (codec) is the same - audioformat is the same
i think thats about it...
good luck
| NuPogodi |
| Posted: Apr 8 2004, 07:31 AM |
| QUOTE (Tongari @ Apr 7 2004, 11:55 AM) | | I need to Combine multiple sets of image files i captured from video. is it possible?...because these images are taking alot of space on my pc. |
@Stephan: i've understood that Tongari needs to compress sequence of images, but not sequence of avi's. @Tongari: there are, imho, more effective methods to save HDD space. If your images are BMP, you can either use archivers (zip, rar, etc) or convert images into lossy formats (JPG, GIF, etc). If you nevertheless want to join your images into avi, goto File -> Open -> Select "Image Sequence" (VDub opens bmp, tga; VDMod - bmp, tga, png, jpg) and encode them with a certain framerate (fps)... during a playback, each image will be displayed 1/fps-seconds.
-------------------- Optimists believe that they live in the best of existing worlds. Pessimists are afraid of that's right... |
| stephanV |
| Posted: Apr 8 2004, 07:43 AM |
@nupogodi: whoops! i think youre right
@tongari: you can do it like Nupodgi says, but you will have to number every sequence: filename00.bmp to filename99.bmp (or whatever the number is).
but, like Nupogodi also said, there are better ways to do this... cant you burn them on a CD? (after archiving)
| Tongari |
| Posted: Apr 8 2004, 03:48 PM |
Thanks
so there's no way i can have 2 different sets of sequences ( ex. Fight00- Fight99 and Hold00- Hold99 )
and combine them? |
| NuPogodi |
| Posted: Apr 8 2004, 04:29 PM |
| QUOTE (Tongari @ Apr 8 2004, 09:48 AM) | | so there's no way i can have 2 different sets of sequences and combine them? |
why not? say, encode each sequence as avi and merge these avi into a single file... but read, at first, a post which wise Stephan wrote at the very beginning .
| stephanV |
| Posted: Apr 8 2004, 04:48 PM |
| QUOTE (Tongari @ Apr 8 2004, 05:48 PM) | so there's no way i can have 2 different sets of sequences ( ex. Fight00- Fight99 and Hold00- Hold99 )
and combine them? |
this could also be done if you give your first sequence the number 000 to 099 and then the next sequence the same filename with number 100 to 199, so it would load the 2 sequences in one time, so you could also encode it at one time
BUT when importing image sequences its important that the (frame)size of the images is the same, it wont work otherwise
| QUOTE | | but read, at first, a post which wise Stephan wrote at the very beginning |
| Tongari |
| Posted: Apr 8 2004, 06:27 PM |
okay i think i got it |
| Tongari |
| Posted: Apr 10 2004, 02:23 PM |
ok one very last thing THE VERY LAST ................. how do i change the first frame filename?
in other words i want to start with 100 not 0 |
| stephanV |
| Posted: Apr 10 2004, 05:13 PM |
uhm
dunno actually... what is exactly you are doing now?
| Tongari |
| Posted: Apr 12 2004, 01:25 AM |
what i'm doing is taking existing scenes from video on my computer, but i want to time sync them to music ( it's a music video) so i want to use lip and motion syncing. thats why im using image files, i want to be able to import them into VDub all at once and work more from there. |
| stephanV |
| Posted: Apr 12 2004, 09:28 AM |
i think the easiest way is using Irfanview (its free) and do a 'batch rename'. it will let you choose how much digits you want to use and at which number you want to start.
