| ABADDON |
| Posted: Oct 18 2002, 02:27 PM |
I have a movie thats to big to fit on a 700mb cd-r, and i heard you can split a movie in half, anyone know how i can do this? |
| ChristianHJW |
| Posted: Oct 18 2002, 07:16 PM |
Virtualdub will allow you to do this, using the 'Direct Stream Copy' modes. There are nice Guides about how to do it on both doom9.org and everwicked.com. Use nandub instaed of virtualdub if you are not sure if your audio is CBR or VBR.
But there is another possibility, if your file is < 800 MB :
Transmux the AVI into an OGM file using OggMuxer from koepi, and use the apps from http://xcd.sourceforge.net to burn it in mode 2 form 2 mode onto a normal 80 mins CD, without overburning....
