| Kaze |
| Posted on Oct 12 2002, 05:26 AM |
I was wandering whether anyone of you could comes out a method for me to convert DVD to Mpeg4 , i try out alot of guides on the web and i got stuck,there is one problem i stuck with virtualDub,
here it is the error comes out when i want to open the file
VirtuaDub Error
Couldn't locate decompressor for format 'vifp'(unknown) VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video.Direct Show codec,such as those used by Windows Media Player,are not suitable.
Well hopefully anyone of you could help me solve this problems or else i would really need to go find other methods...
thx
| BaronVlad |
| Posted on Oct 12 2002, 08:31 AM |
Terrorhörnchen
I voted for "What should I do"
You cannot load vobs or mpeg2 files directly into VDub
Please use the search function of this board or just look about two postings under your thread:
http://virtualdub.everwicked.com/index.php...229f8f483555f6b
