Making Wdm Use S-video As Default In Vdub?
jdg
Posted: Oct 8 2002, 12:24 AM
After every reboot I must change the wdm driver settings in virtual dub to use s-video as the capture source, rather than tuner which is default.
How can I save this between reboots?
Kippesoep
Posted: Oct 9 2002, 01:40 PM
Have you tried saving the capture settings and video format under Capture... Preferences... ? Also, if you have a Bt8x8/Bt8x9 based chipset, try using the btwincap drivers, which store the last-used input themselves.
jdg
Posted: Oct 9 2002, 10:17 PM
Yes, I've tried saving all options in Virtualdub. None saves the wdm driver setting to S-Video.
My card is geforce4 with philips chip, so those drivers are not an option.
2 replies since Oct 8 2002, 12:24 AM Track this topic | Email this topic | Print this topic
