| dtrump |
Posted: Oct 7 2002, 07:18 PM |
Hello, I have a problem with Virtual Dub. I see a great picture, but no sound at all. I have Virtual Dub 1.4.10. A SBLive 5.1 card, with the latest drivers. Windows XP, I have the Build 7 Nimco codecs. I am copying from the video. I can see the picture and hear the sound through the PC but I cannot get any movement on the volume meter. |
| Neo Neko |
| Posted: Oct 7 2002, 10:05 PM |
VirtualdubMod Alpha tester
How is the sound run to your computer? Do you have the corect inputs selected? |
| Zilog |
| Posted: Oct 8 2002, 12:17 PM |
yeah, sound is surely not selected from "line-in" on your sound panel, noooo ? hmmm? so you can hear it but it's not recorded he he....
Don't forget to tell us if this solves your problem... |
| dtrump |
Posted: Oct 17 2002, 08:06 AM |
Problem solved. It was due to my video has 2 scart connections and I was using one to see the image on TV and the second was used for VD. So I took the video to the PC and used the scart connection I was using for the TV and I got sound. Thanks for the help anyway. |
