I am not able to set the right tv channel I want to capture under WinXP Pro. Under WinME the only thing I had to do is to open a TV viewer, set the channel, close the application and then start virtualdub. But under WinXP when I start virtualdub there is always the same channel set for capture, regardless my settings in the other tv programs.
any solutions or programs to fix this problem ?
I installed all drivers and applications for my hardware: -Hauppauge Win TV PCI FM card -Win TV 2000 application -Virtualdub 1.4.10
thanks, Kai |
