| Kallenin |
| Posted: Oct 1 2002, 12:32 PM |
Hey,
I was using VDub to compress a 33.x GB file i recorded from my TV capture card (640x480 VGA), and I had one slight problem--there is only one keyframe! Is this something funky that VDub is doing or DivX? On the DivX codec settings I know that the Max Keyframe Interval was set to be 300 and the scene change threshold set to be 50%. I also had inverse telecine, basic deinterlace (from DivX, not the VDUb filter) and audio in PM3 44KHz 128-bit. It compresses fine and nicely but I'd like to be able to browse around a video file! Where did my keyframes go??? Who is th culprit? Me? DivX? VDub?
-Kallenin |
| ChristianHJW |
| Posted: Oct 2 2002, 01:45 PM |
Will it play at all ? How did you find out there is only one keyframe ? How big was the resulting file after compression ?
