| LongJohn210 |
| Posted: Apr 29 2003, 08:52 PM |
The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input mactch those of the requested format
thats the message i get when i try to extract the audio or even try to encode a movie with the audio with it on full processing mode. heres my file info.
Video stream-------------------------------------------------------------------
Fram size, fps,(us per frame).................608x,23.976fps (41708) # of frames (time):.................................90349 (1:02:48) Decompressor:.......................................Divx MPEG-4 Low Motion Number of key frames:...........................2048 Min/avg/max/total key frames size:......767/12582/46388(25607K) Min/avg/max/total delta frame size:.....78/5591/65045 (481999k)
Audio stream-------------------------------------------------------------------
Sampling rate:......................................48000Hz Channels..............................................5 (stereo) Sample precision:.................................0-bit Compression:.......................................Dolby Digital AC3 Preload skew:......................................28000 samples (0.50s) # of frames:.........................................90339 Min/avg/max/total/frame size:.............28/2335/28000 (206078k)
| endorphin |
| Posted: Apr 30 2003, 03:07 AM |
You probably have your chosen audio output compression set to some setting that is not 48kHz; while your input/source material has 48kHz audio. For example if you were decoding to a 44kHz .wav file or to a 44kHz mp3 this could happen.
Try playing with the Audio > Conversion settings, or choose a different output compression setting or codec. |
| Posted: Apr 30 2003, 03:27 AM |
Hint: VirtualDub can't convert 5 channels to 2.
| smuncky |
| Posted: Sep 14 2003, 01:36 AM |
im bringing this topic back beacuse i have the same problem but there r no solutions here.
how do u convert 5 channels to 2???????? |
| Posted: Sep 14 2003, 03:05 AM |
My AC-3 Decompressor will do it.
| smuncky |
| Posted: Sep 14 2003, 04:16 AM |
man ty sooooo much!!!!!!! it works now...i love u man!!!!! |
