| dawilly |
| Posted: Sep 27 2002, 02:49 PM |
as I try to begin a processing, I get error message to specify "rekeying" under options , but I have no such choice under options - (help!) |
| Posted: Sep 27 2002, 03:35 PM |
When you open the AVI, check the box in the Open menu that says "Popup extended open options." When the popup menu appears, check the first box that says "Re-derive keyframe flags." Be warned that rekeying can take a long time.
